Not Getting Fire to the Plugs
Old Sep 13, 2008 | 08:26 AM
nolimit's Avatar
1988 toyota 4x4 pickup just rebuilt the motor. Last weekend tried to start for the first time found I had a fuel pump problem now I've replaced the pump and I'm not getting any fire to the plugs. Also was not getting power to the pump so jumped it. Checked the air gap on distrbutor it's with in specs. Any suggestions out there.
Old Sep 13, 2008 | 12:03 PM
abecedarian's Avatar
all the plugs to the ignitor connected? is the harness from the engine to the ecu completely connected? all your fuses good? coil installed properly?
just throwing things out there.
Old Sep 13, 2008 | 01:40 PM
nolimit's Avatar
Okay what I've found is that the diagnostic connector has no voltage to the b+ termial. By jumping an ignition wire to the b+ terminal I get fire an power to my fuel pump. The truck will start now as long as I pat the accelerator but runs rough as hell seems to be getting to much fuel. When I run diagnostic check I get a code 51. Anyone have any suggestions. Thanks
Old Sep 13, 2008 | 02:17 PM
thook's Avatar
51
SWITCH SIGNALS
IDL (tps) CONTACTS OFF, NEUTRAL START SWITCH OFF, A/C SWITCH "ON" SIGNAL TO ECU
WITH DIAGNOSTIC CHECK CONNECTOR SHORTED
--A/C SWITCH/CIRCUIT
--A/C AMPLIFIER
--TPS/CIRCUIT
--NEUTRAL START SWITCH/CIRCUIT
--ECU
http://www.off-road.com/toyota/tech/codes/
Old Sep 13, 2008 | 02:44 PM
nolimit's Avatar
Thanks will start checking
Old Sep 13, 2008 | 04:15 PM
code 51 is usually the TPS sensor (but not always ).
but the fact you have to jumper power to even get it to run implies something else. so check all your fuses (under the hood and in the kick panel) and fusible links.
... then deal with the code.
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
Doug4320
Mar 24, 2018 10:11 PM
256mbaker
Jul 31, 2015 06:45 PM
msane99
Jul 17, 2015 10:13 AM
ZONAYODA
Jul 13, 2015 07:17 PM
