Non ADD source on a 91 v6?
Old 08-04-2011, 06:02 AM
mlrtime99's Avatar
I've got a 91 V6 4runner with the ADD front axle. My question is what vehicles/years can you pull the non ADD axles from and swap in?
I've got a line on a '86 pickup NON ADD axle and I'm 99% sure it's a direct fit but wanted to check with the experts.
Old 08-04-2011, 07:31 AM
blake.nemitz's Avatar
yup grab the hubs too unless you wanna be in 4 all the time. grab the 86 just make sure the gears are the same
Old 08-04-2011, 05:33 PM
rattlewagon's Avatar
86-95 will work. Truck and 4runners.
Old 08-04-2011, 06:50 PM
Dutchbelly's Avatar
https://www.yotatech.com/forums/f116...osting-204178/
Check out that sticky from page one of the 86-95 tech section. Ton of invaluable stickys on page one.
If just want the gears from the non ADD axles you can swap out the diff and your truck will work exactly the same. The vacuum lines etc. for ADD is in the axle section beside the diff, and just locks/unlocks the driver side of the axle from the diff.
Obmi
10-04-2015 11:30 AM
Thamuel_
Domestic Swaps
10-03-2015 11:15 AM
dbollier123
09-29-2015 05:23 PM
whiteyota93
09-29-2015 02:31 PM
oldblue
09-28-2015 04:07 PM
Quick Reply: Non ADD source on a 91 v6?
