Noisy Injectors
Noisy Injectors
Does anybody else have a problem with the 3.0 and noisy injectors. I thought I had a valve out of adjustment but when I put my stethoscope on the injectors I found my noise issue. Just wondering if anybody just put a set of reman injectors or new ones. Found a set of reman online for 359.00. If you have changed out the injectors on a 3.0 let me know what you used and how they worked.
Yup,
They were noisy before I had them serviced.
They are noisier now that they are cleaned up. Tap, tap, tap......
Everyone keeps telling me I need to adjust my valves. Grrrr, not the valves, just those damn noisy injectors.
I saw one guy who wrapped them with pipe insulation to dampen down the noise a bit. I have never gotten the motivation to pull the plenum to do that.
