New pro-comp shocks installed and clearance issue
Old Dec 15, 2007 | 03:40 PM
SKNKWRX's Avatar
Put innew procomp es 9000s today and in the front the shock body touches the bumpstop on the UCA. This cant be good or right. anyone else had this issue?
Old Dec 15, 2007 | 03:42 PM
fillsrunner4's Avatar
i had the same ones a long time ago no problems. thats weird. do you have a lift on it?
Old Dec 15, 2007 | 03:44 PM
SKNKWRX's Avatar
t bars cranked a bit thats all. BJ spacers go on tomorrow
Old Dec 15, 2007 | 03:49 PM
i bet it happend with the tbar crank. I would chop the bracket off and fab up a new one for it if you can i dont think you could do much to fix it unless you did that
Old Dec 15, 2007 | 03:57 PM
SKNKWRX's Avatar
well tomorrow some grinding wil def happen
Old Dec 15, 2007 | 03:58 PM
Hell yeah good luck and keep us informed
Old Dec 15, 2007 | 05:36 PM
FredTJ's Avatar
Mount 'em the other way around if they can be. Check the specs to make sure.
Fred
Old Dec 15, 2007 | 05:51 PM
SKNKWRX's Avatar
Fred
they said this end down so I mounted them that way
Old Dec 16, 2007 | 05:47 AM
nmtoy's Avatar
Mine did that with the 9000's too. I just ground the bumpstop bracket a little bit and it was fine.
You can't flip the shock because the top mount is a threaded rod and not an eye like the bottom.
When you install your BJ spacers you will have the grinder out anyway.
Robb
Old Dec 16, 2007 | 05:49 AM
nmtoy's Avatar
Oh, and lose the shock boots.
Old Dec 16, 2007 | 06:22 AM
SKNKWRX's Avatar
i like my shock boots i know everyone hates them blah blah blah
bigjstang
Jun 2, 2025 03:56 PM
raptor510
Feb 17, 2017 07:11 AM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
Massmayhem247
Jul 18, 2015 05:46 AM
Coreyr384
Jul 10, 2015 11:13 AM
