New OSK Timing Chain Tensioner Advice
Old 01-25-2016, 07:43 AM
mgklee's Avatar
I installed a new timing chain kit from engine builder on my freshly rebuilt 22re. In the process of putting the timing chain cover and oil pump back on I accidentally put the wrong bolt in the top oil pump bolt hole. Too long of course. I quickly figured this out because the bolt bottomed out against the tensioner and damaged the slipper on my new tensioner. I'm at my budget with this engine & don't really want to have to buy a new one if I don't have to. It damaged the slipper on the tensioner. I'm going to attach a picture to see what any of you think about it if it will be okay or not. Thank you for any input.
Old 01-25-2016, 08:58 AM
arlindsay1992's Avatar
Rubber isn't cracked? Shaft not nicked/scratched/bent? No visible damage to the casing? Shaft slides in and out freely? Everybody will probably suggest that you replace it but if they were in your situation they'd probably all run it as is. If it were me I'd kick myself a bunch then run it.
Old 01-25-2016, 09:16 AM
mgklee's Avatar
Did you not see the picture I attached? The rubber slipper is cracked right where the shaft meets it. It moves as freely as it came out of the box. No bent shaft or nicks in it.
Old 01-25-2016, 10:35 AM
I saw the picture but I couldn't make out a crack, just what looks like a round chunk taken out by the end of the bolt.
Old 01-25-2016, 10:37 AM
mgklee's Avatar
I'll post a better picture. There is no chunk out by the bolt but by where the shaft enters the rubber slipper.
Old 01-25-2016, 06:56 PM
k-ray's Avatar
You obviously do not trust this part to do its intended job. GET A NEW ONE. While everything is still apart. you'll sleep sounder at night.
Old 01-26-2016, 07:07 AM
snobdds's Avatar
Sometimes it's too expensive to be cheap. Chalk this up to a lesson learned and I bet you will never do it again. That bolt gets a lot of people...
Old 01-26-2016, 07:31 AM
mgklee's Avatar
Well I have already bet on it since the motor is almost together. Haha. Do you all use any rtv on the heater hoses coming out the back of the timing cover?
Old 01-26-2016, 07:34 AM
mgklee's Avatar
Here is pictures of the build!
Attached Thumbnails New OSK Timing Chain Tensioner Advice-photo552.jpg   New OSK Timing Chain Tensioner Advice-photo572.jpg
Old 01-26-2016, 06:41 PM
d-wood's Avatar
You should have part of your timing cover gasket for the heater hoses.
yotapwru
Washington
02-15-2019 11:47 AM
Rob2thec
11-07-2015 08:11 AM
Volnychev
11-06-2015 07:05 AM
krusty_45
11-04-2015 06:45 AM
Mattluke1
11-02-2015 07:08 PM
Quick Reply: New OSK Timing Chain Tensioner Advice
