Need help regarding "Hesitation or stumble during acceleration"
Old 09-10-2009, 02:26 PM
A.Wilson013's Avatar
Hey, guys. My 87 SR5 4Runner just started doing this today. I am curious if anyone else has had this problem with theirs, and knows how much any of the fixes may cost?
Haynes lists these as the possible fixes--
1. Ignition Timing Incorrect
2. Ignition system not operating properly
3. Dirty or clogged carburetor or fuel injector
4. Low fuel pressure. Check for operation of the fuel pump and for restrictions in the fuel filter and lines
5. Carburetor out of adjustment (Should not apply as I have efi, correct?)
A couple days ago I bought some Seafoam and poured it into the gas tank to clean the fuel injectors, and now this is happening. I have a hard time believing that this is a coincidence. I have not messed with anything else...
Thanks for looking, interested to see what you all can offer in advice or thoughts.
Alex
Old 09-10-2009, 04:11 PM
abecedarian's Avatar
Have you burned through the tank of gas you put the seafoam in?
Have you checked your spark plugs?
Old 09-10-2009, 04:48 PM
Yes, I actually noticed the problem right as my fuel light came on this morning.
As far as checking the spark plugs, I could look at them all day, but I have no idea what I would be checking them for.
Thanks for your response.
Alex
Old 09-10-2009, 05:09 PM
myyota's Avatar
Have you ever changed the fuel filter ?, that would be a good place to start, and go from there, its possible that the sea foam broke loose some crap in the fuel system and it might have worked its way to the fuel filter.
Old 09-10-2009, 05:36 PM
Originally Posted by myyota
Have you have ever changed the fuel filter ?, that would be a good place to start, and go from there, its possible that the sea foam broke loose some crap in the fuel system and it might have worked its way to the fuel filter.
That's exactly what I was thinking, and no, I don't think it has been changed.
Thank you.
Alex
Firefightersink15
11-23-2015 10:32 PM
83yotastockR
11
11-10-2015 06:54 AM
shredder4286
10-01-2015 01:09 PM
sanctfy
09-13-2015 06:33 PM
Boomer8404
09-10-2015 09:01 AM
Quick Reply: Need help regarding "Hesitation or stumble during acceleration"
