mystery cv noise
Old 03-26-2007, 01:13 PM
PoleVaulter95's Avatar
mystery cv noise
fyi 95 4runner 3.0 auto 4x4 manual hubs
well it start it off i have some noise problems. it is a rattling metal on metal contact when i go over ruff (SP?) road. i crawled under my car to see where the noise was coming from. when i grabbed onto the cv shaft and gave it a shake it hits metal on metal. the noise is coming from where the cv shaft enters into the wheel area. it happens on both sides and doesnt matter if hubs are locked in or not. i replaced the left cv not too long ago (due to a ripped boot) and it still makes that noise. any help or idea of why it could be making this noise would be helpful. (it just gets annoying hitting little bumps in the rode and thinking something is going to drop out of the bottom of your car)
thanks david
Old 03-26-2007, 01:16 PM
ChickenLover's Avatar
I had the same problem and I know what you mean about it being annoying. I found it quite embarrassing, to tell you the truth.
Your inner spindle bushings are worn out.
Old 03-26-2007, 01:23 PM
JEBSR5's Avatar
x2 on that. Replace both inner and outer bushings, then make a spindle lubricator. Search forum on that last word. Lubricate once a year.
Old 03-26-2007, 01:25 PM
tc
tc's Avatar
x3 on spindle bushings
I think once a year might be a bit excessive though - it took 12 yrs for mine to run dry!
Old 03-26-2007, 01:31 PM
JEBSR5's Avatar
You don't repack your wheel bearings once a year? I do, squirt a little grease in spindle lubricator also, since I'm there.
I guess it depends on how much wheeling you do and water you go through.
Old 03-26-2007, 01:35 PM
tc
tc's Avatar
I check them frequently and grease when needed - I'm usually in there more than once a year anyways.
I will certainly agree that you should lube the heck out of the bushing while you're changing a CV!
Old 03-26-2007, 04:41 PM
well i did use make that spindle bushing lubricator (cant think of who posted its write up but def. good stuff). are these the little bronze copper looking things? i think i have seen a write up on here on how to replace them. sounds like extensive. but since they are "shot" just adding more grease wont settle things out?
Old 03-26-2007, 04:42 PM
slosurfer's Avatar
I did this to my driverside when I changed the cv about a month ago, no more noise. But, it only lasted till the last day of the DV trip, now it is noisy again.
zytra
01-24-2019 03:16 PM
Davebarbier
11-03-2015 03:28 PM
zombie_barbarossa
10-02-2015 10:54 PM
JPV
09-28-2015 03:15 PM
Quick Reply: mystery cv noise
