My a340h shifts at 4000 any way to make it hold gears longer?
Below is one of them
http://youtu.be/M57MrrZ3NOo
well i was up tonight watching youtube videos came across this..
and also an update, got my obd2 hooked up and i got 8 codes more then half where related to the rear o2 sensors evap pressure sensor and coolant temp sensor..
i have already replaced the coolant sensor and upstream o2..
i did get a tps code that i may have fixed when i tested it i bent one of the prongs off to the side..
what i'm worried about is the p1700 code= speed sensor... i believe that to be the big problem..
i talked to the po and he said he didn't hook the speed sensor up for the tranny because the sensor isn't compatible with the newer 98 ecu!
any way to get around this?
cant do a 5 speed swap for a while and swapping to a a340f isn't gonna happen..
ill be getting another od2 reading monday
Jnkml
07-06-2015 01:20 PM
