Modifying Kayline 4runner Soft top
Old Jun 25, 2008 | 06:46 PM
'884Runner's Avatar
A friend of mine gave me an older Kayline soft top that he ended up with (That's right, FREE!). I was wondering, first, what kind of holes do you have to drill to mount the top as it comes from the factory? Are they on top of the bed rails or on the sides of the cab? I would prefer not having to put a bunch of holes that can lead to rust. Also, is it to possible to modify these tops so that they can be installed without drilling? I will have to replace a few snaps that have messed up and clean it up really well, so I don't mind trying to modify anything if it's a fairly easy project.
Old Jun 25, 2008 | 06:51 PM
Djlarroc's Avatar
http://www.off-road.com/trucks4x4/ar....jsp?id=305997
Good luck.
Old Jun 25, 2008 | 07:19 PM
4runnerx3's Avatar
I have a brand new, never been used kayline top, just don't want to drill holes, so it sits in the box. 4crawler has the brackets that allow you to bolt without drilling.
http://www.4crawler.com/4x4/CheapTri...op/index.shtml
Old Jun 25, 2008 | 07:42 PM
86Original's Avatar
Exactly why I've refused to buy a Kayline / STC top. Softopper is making one that requires no drilling. I'm getting one (on its way) from KillerToyTops.com which is also a "no-drill" design.
Old Jun 25, 2008 | 08:40 PM
'884Runner's Avatar
Yeah, I totally agree. If I were buying a top, I would have definetly bought one of the Killer Toy tops, but this was a freebie. Much easier on the pockets, even after modifying it. Thanks for the links and information.
Old Jun 25, 2008 | 08:46 PM
Luvmeye22re's Avatar
If you know anyone that welds/fabricates it should not be hard for them to come up with the brackets necessary to make your top bolt on. I agree completely though, I would NEVER drill a hole in the body of my 4Runner. Maybe one of the Runners I've owned in the past but they were far past worrying about hurting them.
'884Runner's Avatar
Another quick question: does the kayline roll up on the sides like a can-back? Because I noticed that it has three female snaps on the top of it on each side, but I can't figure out where the male counterparts are.
Old Jun 25, 2008 | 08:51 PM
4Crawler's Avatar
Easy way to install a Kayline top:
- http://www.4crawler.com/4x4/CheapTri...tTopInstallKit
Sides and back roll up:
Old Jun 25, 2008 | 09:26 PM
'884Runner's Avatar
Post
Hey 4crawler, about how many screws did you have to drill at the end of the frame that go into the truck when using your kit? And also, are they on top of the bed rails where the hard top will cover them when it is in place? I think your kit is probably going to be the best way to go. Thanks for the pictures.
Old Jun 25, 2008 | 10:00 PM
4Crawler's Avatar
You need a few screws on the ends of the pieces on the cab and likewise at the end of the bed and on the tailgate. All are covered by the hard top and/or gasket when the soft top is off.
Old Aug 7, 2010 | 07:22 PM
bikerbob's Avatar
Bumping an old thread.
I just installed a Kayline on my rig and I am looking for some pics of where the footman loops go.
thanks
Old Aug 8, 2010 | 12:10 PM
4Crawler's Avatar
Just on the back of the bed rail, under the straps off the rear corners.
Old Aug 8, 2010 | 12:38 PM
BigBluePile's Avatar
I used the spot where the last hard top bolt goes and bolted a piece of uchannel(actually it's an old set of Hella 500 mounting brackets) there with a cross bolt to tie off the straps.
Old Aug 8, 2010 | 12:39 PM
You should swing by man! I gots the soft top on now if you need any more help!
Old Aug 8, 2010 | 02:05 PM
bikerbob's Avatar
Thanks 4Crawler ad Blue.
I got it all finished now.
Blue you should head up my way sometime and we can wheel Walker Valley. Plus we are a few months away from snow wheeling season.
Here are a few crappy cell pics of the finished job.
Old Aug 8, 2010 | 02:06 PM
Sounds great man, I haven't been to Walker yet, still building my rear armor.
Road Bull
Oct 10, 2015 04:55 PM
87turboPA
Jul 12, 2015 07:49 AM
msane99
Jul 11, 2015 08:08 PM
crashburnoveride
Jul 10, 2015 06:39 AM
coryc85
Jul 6, 2015 04:07 AM
