manual hubs came with different clutch sizes?
Old 02-06-2016, 07:01 PM
captainslow's Avatar
I just did the whole ADD to manual swap and everything went well. Mostly.
The two clutches I received are slightly different. One is a little taller (if laid flat) than the other. Everything I read shows that they should be the same size right?
They bolt up great and everything fits, however I'm still spinning one CV. It won't even disengage on the bench. I can machine it down but would prefer not to.
1: is there a right and left?
2: does anyone know where I can buy 1 clutch?
I have the FSM but it doesn't show a part number for just the clutch. Thinking about heading over to Toyota on monday.
the word 'CLUTCH' throws people off, so see photo below
Old 02-06-2016, 07:45 PM
muddpigg's Avatar
Always seen them as hub gears. Inner and outer (well at least on SFA) been years since I had IFS. But if memory serves they should both be the same, no left or right. Did you pull them from donor?
Old 02-07-2016, 12:23 AM
wyoming9's Avatar
Red face
Sounds like he bought these Hubs in a box in pieces .
Maybe a do it yourself rebuild your hubs kit from a place in Alabama that will remain unnamed !!!
I would not call a hub gear a clutch either but Toyota has some different names.
Old 02-07-2016, 06:13 AM
I wouldn't call it a clutch either, but hey, the guy who's task it was to name the 25,000 parts probably got a little tired by the time he got to manual hubs and just went for it.
I didn't pull them, it was a parts kit I purchased off of ebay. Supposed to be for off of an IFS 4runner, so looks like I'll be requesting a partial refund.
When I pull it to grind it down I'll take a photo for reference. Thanks for the help guys.
Old 02-07-2016, 06:33 AM
MudHippy's Avatar
Everything you need to know.
Old 02-08-2016, 09:10 PM
Originally Posted by MudHippy
Weird. This shows that the slide gear should be the same in all versions. Now I have no idea where this one came from. I contacted the seller, he's sending me another one so I guess problem solved. Except the mystery about what vehicle it came from.
SacRunner
3.4 Swaps
12-03-2021 06:31 PM
4x4-runner
08-17-2020 01:52 PM
dbbowen
12-03-2015 12:48 PM
RBK
11-18-2015 04:53 PM
95_n130
11-13-2015 06:46 AM
Quick Reply: manual hubs came with different clutch sizes?
