lower ball joint removal question
Old 03-26-2009, 04:47 PM
defiant0116's Avatar
I have a 86 Toy SR5 4x4 and I need to replace the lower ball joint per alignment shop. I tried everything to my knowledge and can not get the lower ball joint to budge. I use a ball joint remover tool and all it did was busted my booth. What tools should I use or attempt should I take to loosen this son of a gun off....please advise....
Old 03-26-2009, 04:57 PM
Tubbyfatty's Avatar
I used a pickle fork to get mine out...worked just fine, well i did have to hit it pretty hard but they came out.
your story sounds kind of odd tho...
Old 03-26-2009, 05:00 PM
BigBluePile's Avatar
I used a tie rod end puller and it work great. I had to kinda hammer into place but not issues. I also coated every thing with PB and use my BFH to help things along.
Old 03-26-2009, 05:35 PM
ovrrdrive's Avatar
If your "ball joint removal tool" is a pickle fork you just need a bigger hammer and to go eat some wheaties. It will break loose, you just have to beat the hell out of it.
If you're using a real ball joint puller just set some good tension on it and then tap the LCA and the ball joint with a hammer and it will break loose.
If it's still the OEM bj it's almost welded in.
Old 03-26-2009, 05:39 PM
iamsuperbleeder's Avatar
yep, I found the best way was to put tention on it, strike the LCA right where the lower BJ is a few times with a hammer, then put a little more tention on it, and repeat
might take 2 or 3 goes at it, but it'll pop off
out of all the front suspention parts, I think the BJs on the LCA are the most stubborn
Old 03-27-2009, 05:43 AM
Thumbs up
thanks for all you guys opinion....I will put it to use and inform which method is better....thanks again.
Old 03-27-2009, 06:06 AM
mt_goat's Avatar
The best tool I've found for that is a pitman arm puller. Something like this one: http://toolsandmore.us/index.asp?Pag...ROD&ProdID=341 I've always borrowed them from the Autoparts places, but I should just buy one I guess.
Old 03-27-2009, 11:41 AM
This is what I used:
http://www.napaonline.com/NOLPPSE/(S...17_0006402319#
Old 03-27-2009, 01:17 PM
yeppers, her's mine
technically a pitman arm puller, but it worked just as good
picked it up at the local parts store
Old 03-27-2009, 01:40 PM
Originally Posted by iamsuperbleeder
yeppers, her's mine
Yup, scored mine at NAPA!
kazuya2416
04-05-2024 02:17 AM
09-04-2015 09:27 AM
msane99
07-27-2015 06:14 PM
1994toyota
07-17-2015 03:03 AM
shisha1999
07-13-2015 11:09 PM
Quick Reply: lower ball joint removal question
