Low Fuel (Dummy light) is out
Old 08-02-2006, 11:20 PM
SoCal80's Avatar
Well tonite I realized that the low fuel light is not working completely. I have searched and read a few threads about the low fuel sender unit. Could this be the only issue or is there something else I should look at first? The light was working up into just 2 to 3 wks ago. Any help would be appreciated.
1986 22 re auto 4R
Thanks
Steve
Old 08-03-2006, 02:07 AM
TNRabbit's Avatar
I'm interested in this, too, as my low fuel light has NEVER worked since I bought my '94 4x4 xtracab 3vze over 110,000 miles ago....
anyone?
Old 08-03-2006, 05:33 AM
05prerunner's Avatar
maybe just a bulb? have you pulled the cluster out and tried swapping with a different bulb to see if that does anything
Old 08-03-2006, 06:53 AM
DirtCheap's Avatar
Really, check the bulb!
Old 08-03-2006, 08:35 AM
as2sb3100's Avatar
Mine has to get realy realy low for the light to come on. When I first bought it I thought it didn't work, but it does. My guess is that if your fuel gadge works, then the light works, unless it's burnt out or something. Have you run it until it's outa gas? Just cary an extra couple gallons of gas and try it. I've always been kidna curious as to how low it can realy go.
Old 08-03-2006, 08:43 AM
SoCal80's Avatar
I ran it all down yesterday! I was about 100 yards away from the gas station!!! lol
I will check the bulb today and see what happens. I will report back as soon as I can. I will be going out of town so might not be till Sunday.
Thanks for help guys!
Old 08-03-2006, 09:54 AM
gohawks's Avatar
I've often wondered if mine works. My gauge always shows "E" but when I fill up it takes less than the capacity of the tank, ie I still have a couple of gallons left. So I really don't know if mine works or not.
Old 08-04-2006, 08:55 AM
aviator's Avatar
My idiot light has never worked and the light on my friends old truck never worked from the day he bought it brand new.
I think some of the sender units either did not work at all or else they were only connected as part of the full sr5 option package. but I will check my bulb next time I have the dash open though I thimk its a diode.
Aviator
Old 08-04-2006, 09:13 AM
brandontrek's Avatar
add one to this list of "never worked"
i have run my 3vze to 320 miles on one tank and the needle on the E and still haven't seen the light....
Old 08-04-2006, 05:47 PM
dino1967's Avatar
my 95 has never worked either but i have never ran it all the way out gonna have to put my can in the truck and see if it does work
Old 08-06-2006, 09:09 PM
dwiegand's Avatar
I keep a can in the back of my 3.0 but I haven't run it all the way out of gas. I have brought it all the down to 1 gal remaining and my light still didn't go on. I checked my bulb today and that was fine so Im not sure if it will go on after I take it down to less than one gallon or the sender is bad but my fuel gauge still works good.
Old 08-06-2006, 09:12 PM
superjoe83's Avatar
it was an option on some trucks, my '99 taco has the spot for the bulb, but is not wired for it
Old 08-07-2006, 10:19 AM
snap-on's Avatar
the one in my truck doesnt work... hasnt worked sence 99 or so
the one in my 4runner still works fine.
Old 08-07-2006, 10:35 AM
Bear80's Avatar
The units are pretty simple and not prone to failure, probably a shorted or fraied wire ontop of the tank. ALL trucks came with it regardless of trim level.
IF your gauge reads wrong, you need to drop the tank and bend the float arm. OR the arm has worn out of the grove on the float. Both issues are due to the fact that there are NO baffles in the tanks and all that gas sloshing around on the trail puts a beating on the float arm.
Old 08-07-2006, 11:07 AM
4runnermt's Avatar
I know mine works, cause when I am almost on empty going up a steep hill, the light comes on.
Charecter1
11-06-2023 10:08 AM
jbv808
08-06-2021 04:47 PM
Sleaker
08-26-2020 06:03 AM
09-04-2015 09:27 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Low Fuel (Dummy light) is out
