Loud Vibration from 1986 pickup
Old 06-02-2016, 09:20 AM
YotaFitzy's Avatar
Hello guys, hopefully I'm in the right form. While I'm driving I've been getting a loud vibration when accelerating over 1500 rpm and then once I let off the gas the rattle is there until it drops below 1500rpm. I'm thinking it's the u-joint but I don't have much experience. Thanks for any help!
Old 06-02-2016, 09:33 AM
highonpottery's Avatar
I'd say ujoint or a tire out of balance, perhaps even carrier bearing if its an xcab. Test ujoing by grabbing the driveline and try to wiggle the joint by hand. You can also use a screwdriver wedged inside the joint to see if you can observe some play. There's youtube videos of how to check them too.
Old 06-02-2016, 05:30 PM
YotaFitzy's Avatar
Thanks for the help got her all figured out!
Old 06-03-2016, 07:52 AM
And it was.....
Old 06-03-2016, 09:47 AM
YotaFitzy's Avatar
There's a bit of play in the ujoint but most of the noise is coming from the exhaust manifold... there are 3 screws holding it on, and the one at the back (couldn't see it) was gone so its just a rattling nightmare. Lesson learned to check the easy stuff first. Thanks for the help
RV8guy
21
10-02-2017 07:04 AM
jessie301
06-07-2016 10:18 PM
Hallam Cook
06-02-2016 12:00 PM
AZ_98_4Runner
06-02-2016 08:08 AM
69SSRat
05-18-2016 04:28 PM
Quick Reply: Loud Vibration from 1986 pickup
