license plate light wiring
Old Jan 17, 2006 | 07:09 PM
pullnshoot25's Avatar
I think something happened to the wires on my license plate lights (I dont really know how), because I put in new bulbs and they still wont light up. ISince I dont want to get pulled over by Officer McFriendly anytime soon, where is the fuse/relay/wire for the license plate light located?
Old Jan 18, 2006 | 07:34 AM
Marc's Avatar
They are on the same curcuit as the tail lights, dash lights and side markers. If these are still working then the fuse is ok.
Could be the wires between the license plate and the body.
Old Jan 18, 2006 | 09:31 AM
i_rifiyou's Avatar
go look under you rear passanger side bumper. and you will see wires coming from the plate going into the cab, my wire was cut in half, just some tape and your done
my 2 cents
Old Jan 19, 2006 | 01:30 AM
thanks guys!
Old Jan 21, 2006 | 04:01 AM
maxpower_hd's Avatar
A bad ground is also common. Use a test light to check the socket to see if there is power to it first. If there is then the problem is with the light or the way it is sitting in the socket. If there is no power, use the test light as a ground wire. Clip it to something that is clean or known to be a good ground for something else and place the tip on the ground side of the circuit. If the bulb lights up then it's definately a bad ground.
Old Jan 21, 2006 | 07:29 AM
mehret's Avatar
you may need to clean the contacts
Jun 1, 2021 01:51 PM
Sleaker
Aug 26, 2020 06:03 AM
Sep 4, 2015 09:27 AM
Johntom240
7
Jul 13, 2015 12:18 AM
