level lift kit 4runner
Hey guys i was wanting to fix my rear sgging problemand buy the level kit. It is 1.50" lift on the rear to level the truck out. Do i need to get new shock to do this can i use my factory ones, and are the spacers ok to use or downey coils.
For coil spacers (I assume what you are asking about), check the shock length and see if they are long enough. Also, spacers are OK as long as the springs are in decent shape (aside from the sagging):
http://www.4crawler.com/4x4/ForSale/...acer.shtml#FAQ
I think it depends on your application. I wanted to retain stock ride (smooth) so I went with spacers. I think the replacement coils are stiffer (from what I've read, anyhow). Mine is a '90 Runner 2wd, and I was told yesterday that they don't make a 1.5" longer shock in the Runner configuration (loop/stem) from Gabriel. I was specifically looking for airshocks to tow with, though. I'm hoping to offset sag when towing with those, keeping the stock ride when not towing.
2% of a bucks worth...
Qdude
Qdude
06-01-2021 01:51 PM
skoti89
07-06-2015 07:45 PM
Vargntucson
07-04-2015 12:15 PM
