Knock sensor signal ?????
Old 04-02-2008, 02:24 PM
swerks's Avatar
Question Knock sensor signal ?????
Im getting a CEL for knock sensor signal, my engine seems to be running fine. what does this all mean? should I just replace my sensor. what am I risking if I ignore it for awhile?????
Old 04-02-2008, 05:24 PM
toyota_mdt_tech's Avatar
Big chore, assuming your sig line is correct, yours will be under the intake manifold. Dont even think of doing it without replacing the wire also (short pigtail). Its almost alwasy the connector (corrosion) and sometimes the wire in the harness, but never seen a bad knock sensor yet.
Old 04-02-2008, 06:08 PM
swerks's Avatar
what happens if I dont fix it ??????
Old 04-02-2008, 07:33 PM
dcg9381's Avatar
Retarded timing.. How retarded isn't likely known.
Less power for sure, worse mileage.. Very retarded timing = high EGTs, but it depends on how much the ECU is allowed to back the timing down.
Old 04-03-2008, 05:56 AM
swerks's Avatar
Can I just replace the wire??? I only get the CEL very intermittantly. I reset and it takes days and sometimes weeks before the CEL returns.
Old 04-03-2008, 06:40 AM
dcg9381's Avatar
S, If you had a 22R series with a damaged wire / connection - I'd say yes.. I don't know what the particular problem is with the V6, other than I know it's a PITA to get to...
Old 04-03-2008, 10:12 AM
swerks's Avatar
Sorry, this is for my 86 turbo I should have mentioned that.
Old 04-03-2008, 11:10 AM
dcg9381's Avatar
So is your wire bad? Is it disconnected at the connector?
You can just replace the wire - but it may be a shielded wire (like coax) - let me know and report back.
Old 04-03-2008, 01:47 PM
swerks's Avatar
Ok I need help! I thought I new where this sensor was at but I cant seem to find it ???? Is it near the distributer??? To top it all off while investigating I found a large tear in my CV boot grease everywhere!!!
Old 04-11-2008, 06:09 AM
Team420's Avatar
it is under the intake, you have to take the upper plenum off then remove the manifold, it will be right there, do yourself a favor and replace the sensor too, i made the mistake of not getting the sensor(just did the wire), and now after all that work i still get the same code!! The first time you get into it, it will b a apain in the butt, and prob take several hours, but after you figure out all the shortcuts it shouldnt take more than 4-5 hrs...goodluck
Old 04-11-2008, 08:13 AM
dcg9381's Avatar
Steve has a 22RTE. It's 9:30 relative to the oil filter.
djohnson13
09-04-2015 12:35 PM
raptor510
08-19-2015 02:15 PM
Flossy
08-05-2015 05:14 PM
nonstop
07-24-2015 06:29 PM
Quick Reply: Knock sensor signal ?????
