| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
knock sensor question.
__________________
'92 toyota truck 22re, header, 5 speed. 3" body lift, 31" michilin tires 26mm torsion NIB(box of the truck that is) needs some TLC clean body, i paied $400 |
#2 (permalink) |
They're cheap and there for a reason. What benefit is there ditching it?
#3 (permalink) |
If your vehicle is supposed to have a knock sensor then it would be more difficult to trick it than to just put one on.
The knock sensor has a piezo electric element that gives off an A/C voltage signal proportional to the vibration it recieves. it is tuned harmonically to the frequency of detonation ( about 7.1Khz) and at that frequency the amplitude of the signal increases tremendously. so if you where to build a A/C frequency transmitter and dial it in to the proper amplitude and frequency that would probably do the trick. But like I said before, it would be a lot easier to just replace it.
__________________
Targetnut don't talk about it, just do it! Precision Import Service '93 2WD 22RE, Ported w/os valves, custom intake manifold, crane cam,Megasquirt, 295cc injctrs, Supra fuel pump, adj fuel pres reg, 70mm throttle, LCE header, V6 Taco cat, 14lb flywheel, Kevlar clutch, W58 and short shifter, 4.10 gears w/Truetrac, drop spindles and blocks, 245/50-16 Yokos on 16x8 wheels, 4WD fenders, bumper, and valence, skinned tailgate |
#4 (permalink) |
aside from the fact that it could save your motor in the event of a bad batch of gasoline, sticking injector, or dying fuel pump. (especially in turbocharged applications)
__________________
My heatercore replacement writeup with pics. -'94 Toyota 4X4, 22re, 31X10.5 BFG M/T's, 5 speed, MC rear bumper. (Winter DD/ off road fun) -'95 BMW M3, modded/suspension, sticky rubber, back road monster (Summer DD) -86.5 Toyota Supra, too much to list. (Never-ending project) |
#5 (permalink) | |
Quote:
Thank you guys for the answer i needed. i'll have to figure out a way to mount the thing now.
__________________
#6 (permalink) |
I purchased a used one off Ebay. Worked like a champ. I drove my truck for awhile without one and it ran fine but turned on the CEL ever time I would drive off.
Now go get one and protect your motor. Ever seen a piston with a hole through it caused by detonation? I have. Failed right in the center where the little dimple is located. Detonation can also beat the he!! out of your top rings. |
#7 (permalink) |
I'd think you could braze a nut with the proper thread onto the engine.
#8 (permalink) |
You can locate it here as indicated:
http://www.lcengineering.com/TechNotes/TechNote21.htm Note, There at least 2 different KS designs - make sure you match thread and KS design to your ECU.
__________________
http://www.22REturbo.net |
#9 (permalink) | |
Quote:
alright, thanks, i've got the tap for it already too, i'll be doing this tomorrow.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 22re Knock sensor vs 3.0 knock sensor | tlake | 86-95 Trucks & 4Runners | 4 | 01-30-2008 09:53 AM |
| Knock sensor? | cmckeon | 86-95 Trucks & 4Runners | 1 | 01-21-2007 09:20 PM |
| knock sensor question | xentrino | 86-95 Trucks & 4Runners | 3 | 09-23-2006 01:38 PM |
| need a knock sensor | ohioyotaguy | 95.5-2004 Tacomas & 96-2002 4Runners | 22 | 01-31-2005 01:04 PM |
| Knock sensor again | Bassinfool | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 01-15-2005 11:28 AM |
