interchangeable caliper question
Old Nov 16, 2007 | 09:52 PM
Booosted Supra's Avatar
I was searching and I was just wondering if the brake calipers from a 3VZE powered pick up(4x4) would swap to a 94 4runner, also with a 3VZE 4x4, i have new calipers on the parts truck just wondering if i can swap them to my 4runnetr because one of mine locked up tonight, if not i guess i'll just have to buy another one
Old Nov 17, 2007 | 04:39 AM
MonsterMaxx's Avatar
pickup & 4runner are the same
Old Nov 17, 2007 | 10:11 AM
i forgot to mention the truck is an 89, i tried crossing part numbers and they came up different
Old Nov 17, 2007 | 04:41 PM
Flash319's Avatar
Yes they changed to a 4 big piston caliper from a 2 big 2 small piston caliper in 89. They all bolt up but the older ones with the 2 small pistons have less power obviously. You will be okay as long as you stay over 89 and under 95. Over 95 may work but not sure.
88sasturbotoy
Jan 30, 2026 01:57 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
garagespace
Oct 11, 2015 10:59 AM
TransAmBandit
Jul 28, 2015 11:30 PM
TDonkey
Jul 26, 2015 10:14 AM
