Installing OME springs-- need brake line?
Old Oct 2, 2006 | 05:32 PM
Jordon Norwood's Avatar
I just bought a set of OME 901's from trdparts4u.com. I am getting some longer shocks to go with the springs.
Do I need the longer brake line? if so, where do I get just the brake line? Also, what about the abs line bracket that is mentioned in the downey write up's?
Can I go ahead with the install and get these items later, or am i gonna rip the old brake line if I do not get the longer one?
Thanks guys!
-Jordon
Old Oct 2, 2006 | 06:20 PM
Bill's Avatar
My lines had plenty of extra play in them, even after I put my 901 springs in. Longer lines are something you could do eventually (especially if you do lots of wheeling), but not 100% needed yet.
Old Oct 2, 2006 | 06:25 PM
callmej75's Avatar
I concur
Old Oct 2, 2006 | 06:39 PM
Thanks!
Most of my driving is on road, so sound like i'll be fine. I'll be sure to post before and after pics.
Old Oct 2, 2006 | 07:13 PM
SacRunner's Avatar
Measure your brake line, the acutal rubber portion, my '91 had a 9 inch long rear line and let me tell you, it was a TIGHT fit. To drop the axle far enough to get the old springs out (even with strut compressors) I had to unscrew most of the hard line mounting tabs from the axle housing, and even then (with the brake line stretched out) I didn't feel comfortable going any further.
I read somewhere that the "stock" length was 11" and at 11" I'd have been fine, but with the 9" lines, I decided to go get some ProComp lines for ~$80.
https://www.yotatech.com/forums/f120/toyota-faq-66255/ has some pretty good info on the brake line options.
just my experience.
EDIT: and yeah, everyone told me I'd be fine without replacing the brake lines
Old Oct 2, 2006 | 07:22 PM
slosurfer's Avatar
If you do need a longer brake line and want to save a little money, you can buy another stock brake line and add it to your original.
Old Oct 3, 2006 | 01:54 PM
What about the bpv bracket? whats its deal?
Sep 4, 2015 09:27 AM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
bryan34w
Jul 6, 2015 05:53 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
