Installing OME dakar rear leaf springs
Old 04-28-2007, 06:26 AM
swerks's Avatar
Cool Installing OME dakar rear leaf springs
I will be installing rear leafsprings this weekend any one have any tips or tricks to help with install before I get started??? Hope this goes better than the torsion bars went last weekend.
Old 04-28-2007, 06:31 AM
RustBucket's Avatar
Spray some penetrant on all fasteners that need to come off!!!
Old 04-28-2007, 06:39 AM
swerks's Avatar
Ive been hitting them with the PB blaster for the last three days
Old 04-28-2007, 07:39 AM
swerks's Avatar
my new springs are several inches shorter than the old is this a problem I realize the old springs are mashed down almost flat at this point.
Old 04-28-2007, 07:42 AM
4Crawler's Avatar
Measure the lenght along the arc of the spring. Stock springs are relatively flat with little static arch, should be ~47" center to center on the spring eyes. The OMEs should measure about the same as well.
Old 04-28-2007, 05:33 PM
LTrunner's Avatar
make sure you have new/good bushings, and put some grease on all the hardware going thur the bushings.
good luck
Old 04-29-2007, 05:25 PM
swerks's Avatar
Believe it or not I spent most of the weekend just getting the damn wheels off. They were the only thing I hadnt been hitting with the PB blaster.
Old 04-30-2007, 01:59 PM
swerks's Avatar
OK, my Bolts are not a snug fit in the OME poly bushings. I removed the old metal sleeve from the rubber bushing and thats too big to fit in the poly bushing. how do I proceed.
Old 04-30-2007, 02:31 PM
4Crawler's Avatar
Which end of the spring? Up front should be a 14mm bolt w/ sleeve in the bushing, perhaps OME forgot to send that sleeve. In back, should be 18mm bolts and no sleeves.
Old 04-30-2007, 03:24 PM
swerks's Avatar
are these sleeves available as a part from toyota or OME ????
Old 06-04-2007, 10:12 AM
Jstew52's Avatar
Did you ever get the OME leaf springs installed?
06-01-2021 01:51 PM
jerusry
10-19-2015 05:28 PM
Road Bull
10-10-2015 04:55 PM
Nickdigg
07-07-2015 06:04 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Installing OME dakar rear leaf springs
