Install Report: TRDParts4u lift kit
Old 02-05-2007, 06:59 AM
chimmike's Avatar
This is the one with the stabilizer, HD rear coils, 2" rear spacers, Balljoint spacers, and OME shocks all around. 3-4" lift.
Rears were cake. Springs required major compressing via spring compressors, but once they slid in, BAM! And they are HD! I could load 200lbs+ in the back and it doesn't budge. Good stuff.
Fronts: The stock steering stabilizer upper bolt thing wouldn't come out. So I sawzall'd the damn thing off. Now I have to drill out the damn hole to install the new one. Cheap drill bits suck. Spending $60 on bits I hope will work sucks (I might change that if I find out they work this weekend).
Balljoint spacer install: Before starting this, MAKE SURE the instructions you have have CLEAR pictures. I had no idea what lip I had to cut off. After an hour I figured it out. Use a cut off tool (air tool). using the 4" grinder w/cut off wheel was a pain in the arse and painful (burns).
Also, I recommend a BIG breaker bar. I'm talking STRONG and about 4' long. This will allow you to get leverage to lift up the upper a-arm in order to put the spacer in and slide the ball joint into place. It takes strength (so some of you weenies may need to call reinforcements ).
Finally:
It rides great! Feels even better. Handles great off road. I'll be posting pics of flex later tonight. Good stuff! Only thing that would be better: SAS.
Also, you NEED the front diff drop spacers and longer brake lines. Both of those will be installed this weekend. (as long as Marlin gets 'em to me this week)
Old 02-05-2007, 08:13 AM
UncleBob's Avatar
Before/After pics?
Old 02-05-2007, 09:28 AM
chimmike's Avatar
before? look at your rig.
After? coming tonight.
Old 02-05-2007, 09:32 AM
da_bigg_wigg's Avatar
so did you happen to take some CLEAR pictures of the procedure?
Old 02-05-2007, 09:34 AM
mastacox's Avatar
It's really a better idea to either jack the frame up far enough to droop the lower a-arm, or unbolt the torsion bar adjusting bolts. No point in fighting a spring made to hold up a 4500lb. vehicle... When I installed my ball joint spacers, I actually removed both upper a-arms (took off the t-bars, etc.), to make grinding easier.
Definitely need to see those after pics
Old 02-05-2007, 09:41 AM
chimmike's Avatar
This is true, but my breaker bar is BEEFY and I was able to pull it up and hold it while my buddy positioned them. Leverage=good
I don't have good pictures of the area but I can explain it a lot better than those SDORI instructions could! "cut lip with angle grinder or cut off wheel" So we scratched our heads...... "ok, what friggin lip?"
Old 02-12-2007, 05:58 PM
boosted313's Avatar
were's the pics? i need a lift.
Old 02-12-2007, 06:17 PM
CJM
CJM's Avatar
Please explain the BJ spacers..I'm doing this soon and will need to know as I cant make heads or tails of them crappy pics either.
Old 02-13-2007, 04:56 AM
chimmike's Avatar
The upper ball joint portion, let me see if I can snap a pic of it later today and upload it.
Old 02-13-2007, 05:37 AM
1styota4X4's Avatar
i just did the lift and i love it....my buddy took pics of the complete install and than his now ex jacked his digital camera and all the install pics...
Flying91
45
04-11-2024 04:39 PM
jerusry
10-19-2015 05:28 PM
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: Install Report: TRDParts4u lift kit
