Important Question About Knock Sensor Wire
Old Jul 23, 2008 | 03:26 PM
4RrunnerJ's Avatar
i found the problem with the knock sensor, it seem the wire came out of connector to the sensor.. i was trying to find a way to route it but it seems the wire is to short, or unless im routing it the wrong way... does anyone know about how long the wire is from the sensor to the connector on the wireing harness,, mine is about 10 - 12 inches
Old Jul 23, 2008 | 03:34 PM
Crawdad's Avatar
Just splice in and make it longer if you're sure that it goes to the knock sensor.
Old Jul 23, 2008 | 03:35 PM
4RrunnerJ's Avatar
thats what i was going to do but do i use electrical wire or just speaker wire
Old Jul 23, 2008 | 03:45 PM
Crawdad's Avatar
It ain't a knock speaker, so don't use speaker wire (although I guess it would work in a pinch).
Old Jul 23, 2008 | 03:49 PM
Cyberman's Avatar
The knock sensor on my 3.0 is a single wire, with a braided shield around it. I had to change connectors on mine. Luckily, I only had to change the connector and not splice it. You could use 2 copper wires, but you might want to keep the lengths as short as you can.
Old Jul 23, 2008 | 03:53 PM
4RrunnerJ's Avatar
ok... do any of u remember how the wire is routed from the snesor to the wire harness... it looks like it goes from the sensor to the back of the block then up into a little hole on the head
Old Jul 23, 2008 | 03:58 PM
76ANTHONY's Avatar
MINE WAS IN THE BLOCK AT TOP UNDER THE MANIFOLD, THEN THE WIRE CAME OUT OF THAT AND WENT THROUGH THE SLOT IN THE HEAD THE HOOKED TO THE WIRING HARNESS
Old Jul 23, 2008 | 04:05 PM
4RrunnerJ's Avatar
where did u get the connector from because my wire came out of it and i dont think ill be able to get it back in
Old Jul 23, 2008 | 06:45 PM
Cyberman's Avatar
I had a spare harness here with a different engine. If I remember, I think you can get a replacement from the dealer. I might have another one here though. If you can, post a picture of yours; is it round or square?
Old Jul 25, 2008 | 10:02 AM
4RrunnerJ's Avatar
well i got the sensor fixed and everything put back together...but now it wont start.. it cranks but wont start... i checked all the hoses and connections and everything checks out good,,, could my timing be off now that the sensor is working
sandyota
Feb 4, 2021 11:16 AM
icentropy
Sep 16, 2020 02:47 PM
88yodabasket
Jul 13, 2015 01:32 PM
smiley52
Jul 11, 2015 05:16 AM
nick b
Jul 11, 2015 04:38 AM
