Ignition Coil
Old 05-24-2009, 08:56 AM
first_toyo_owner's Avatar
Ignition Coil
Hello It seems that i may need an ignition coil for my 90 sr5 2.4l 22re 4runner but i am looking online and i can't seem to find the actual coil I need. Hopefully I am talking about the right thing here. The igniter i believe is this.
http://cpwstore.carpartswholesale.co...L/A358140.html or one a little different depending on make or model, now I am looking for the plugs themselves as appose to just that. I checked lordco and they said 500 bucks for one. Is there anywhere cheaper that i could get one. Does anyone have links for me or even one they can sell me would be appreciated thanks!
Old 05-24-2009, 09:20 AM
so the part number i think i need for the coil with igniter is 19070-35210 K x also there is another pt number 101311-54580 anyone help?
Old 05-24-2009, 10:33 AM
iamsuperbleeder's Avatar
nah, a replacement coil, OEM style from any local parts store, shouldn't run you more than $20-$30, if that IS all that you need
the ignitor is the black box-lke thing mounted above the round coil, and THAT'S what is going to carry a heafty price for a new replacement
You might want to check a junk yard first; they tend to not go out too often, so chances are you would pick a replacement for the same price as a new coil from the parts store, IF that is you problem in the end
what leads you to think either is bad?
Old 05-24-2009, 10:35 AM
toyospearo's Avatar
I HAVE ONE
Its sitting right here... https://www.yotatech.com/forums/f107...oodies-181564/
its yours for $50.00
came off an 83 22r
Old 05-24-2009, 10:42 AM
Originally Posted by toyospearo
I HAVE ONE
came off an 83 22r
the coil maybe, but I believe the ignitor from an 83 would be a bit different from one on a 90, iirc
Old 05-24-2009, 10:53 AM
toyospearo's Avatar
let me know!!
I have two of them
D
Old 05-24-2009, 08:10 PM
its the wrong one i have that igniter already
Old 05-24-2009, 08:33 PM
toyospearo's Avatar
ok!
good luck with it!
Old 05-25-2009, 05:16 AM
well we checked the igniter and the distributer and spark plug and connected the igniter coil directly to the battery and it still didn't fire
Rerun
3.4 Swaps
10-01-2015 12:24 PM
voiddweller
09-28-2015 11:21 PM
mojo4x420
09-16-2015 08:07 AM
JHalcyonM
09-14-2015 01:10 AM
Quick Reply: Ignition Coil
