IFS Front wheel bearing replacement
i drive my truck appox 1600 miles a month on the highway. Now i hear what sound like a noise from my front pass wheel bearing. Ive read through helms and haynes and they dont give much on replacing the bearings, do they need to be pressed out or do the come out easily? and insight is appreciated
Originally Posted by celica
check your brake pads first. I thought that it was my bearing as well, then I found out it was only the low pad indicator rubbing on the disc
Anyone have a PDF on wheel bearing replacement for a 91? I tried searching and can't find much info on replacing them and I left my repair manual back at school. Anything especially dificult about the job?
See this thread...there's a procedure link there:
https://www.yotatech.com/forums/f116/problem-wheel-bearings-hubs-73550/
https://www.yotatech.com/forums/showthread.php?t=73550
Originally Posted by surf4runner
~ bump
Originally Posted by 4Crawler
And another link:
http://www.4x4wire.com/toyota/mainte...t_end/bearing/
thanks thats the best link ive seen on the bearing them self
AustinTaco
06-21-2015 09:54 AM
