i think my fuel pump is going bad - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-23-2007, 09:37 PM   #1 (permalink)
ozziesironmanoffroad's Avatar
Send a message via AIM to ozziesironmanoffroad
i have to give it a lot of gas to keep it running when i start it, every time,no matter if its warm or cold, and it wont idle unless i revv it up really high, then it chugs, but idles. could this be the work of the fuel pump, or a sensor?
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back.
1988 Toyota P/U 4x4
22re, 1200 miles on the rebuild
engine builder .268 cam
pioneer CD deck
31x10.50x15 BFG A/T
BAJA 100W lights on prerunner bumper
KC Daylighters 100W
rancho rs5000
MUD IS A VALID PAINT JOB!
If not living life to the fullest, why live it?
my trucks official buildup thread
ozziesironmanoffroad is offline
Old 09-23-2007, 11:15 PM   #2 (permalink)
anyone have any ideas of what it could be?
__________________
1988 Toyota P/U 4x4
pioneer CD deck
31x10.50x15 BFG A/T
KC Daylighters 100W
rancho rs5000
Old 09-23-2007, 11:31 PM   #3 (permalink)
stormin94's Avatar
I'm not sure, but having 250,000 miles on your truck probably doesn't help things either. I dunno, Check for vacuum leaks.
__________________
1994 Toyota 4Runner SR5 4X4
213,000 miles and counting
3.0 V6, 5 speed
10/15 MPG city/hwy(with 33's)
Current Mods
Headers, 2.5" Flowmaster custom exhaust, K&N FIPK
KC Daylighter 100 Watt lights
Ranchos x4, 2" Lift Downey coils
33-12.50 M/T's, 1" t-bar lift, 1" body lift
Tow pkg w/ lighthookups
Silverstar Headlights, Pioneer Deck w/XM
Brushguard
250Watt JLAudio 8" W3 Sub
Future Mods
12V Aux outlet-400/800peak inverter
roof basket/lights
Air locker
4.88 gears
H.O. Alternator
stormin94 is offline
Old 09-23-2007, 11:32 PM   #4 (permalink)
fillsrunner4's Avatar
Send a message via AIM to fillsrunner4
maybe the fuel filter perhaps. you could undo the line pre filter and turn the key and see if its pumping fuel and if its not then yeah its proibably the pump but I would do that check before you go by a new one. save some $$$
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 39" Iroks, Rear Leafswap, 5.29's , Air locked front, Welded rear, Chevy 4.3L V6, 5spd swap, dual T/C's MC10R10, flatbelly with custom skids, sliders, Chopped, Bobbed and so much more.
Might as well start reading this if ya want know more
Fillsrunner4 3.4crawler Build Thread
Fillsrunner4.3 crawler (Part Two) build thread
fillsrunner4 is offline
Old 09-23-2007, 11:38 PM   #5 (permalink)
corvey's Avatar
I don't think it's the fuel pump. In fuel injected engines, the fuel pump is a very high PSI pump so it can be forced through the injectors and be atomized correctly. I think a fuel pump would fail completely and therefor would not work at all. I would tend to think it would be clogged injectors before thinking it was a fuel pump.
Most likely I think your problem is probably just a vacuum line has come loose somewhere.
__________________
1990 4x4Runner 3.S0LD
"I just saved a bunch of money on my 4runner by switching to Yotatech"
corvey is offline
Old 09-24-2007, 05:32 AM   #6 (permalink)
ok will check. if i have time at work ill clean out the injectors and will see whats going on. thanks
__________________
1988 Toyota P/U 4x4
pioneer CD deck
31x10.50x15 BFG A/T
KC Daylighters 100W
rancho rs5000
Old 09-24-2007, 05:39 AM   #7 (permalink)
OH.... something just popped in my mind... im gonna be checkin the MAF too. when the MAF kept disconnecting itself a year ago, it would do this. its tight, but i think it may be dirty. will let every1 know.
__________________
1988 Toyota P/U 4x4
pioneer CD deck
31x10.50x15 BFG A/T
KC Daylighters 100W
rancho rs5000
Old 09-24-2007, 05:42 AM   #8 (permalink)
mt_goat's Avatar
Quote:
I agree.
__________________
~Dale~
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is offline
Old 09-24-2007, 05:51 AM   #9 (permalink)
sometoyotaguy's Avatar
how's your timing chain?
sometoyotaguy is offline
Old 09-24-2007, 05:52 AM   #10 (permalink)
mt_goat's Avatar
Quote:
A MAF or mass air flow sensor will get dirty very easy and the small heated wire needs cleaning sometimes, but 86-95 trucks don't have MAFs, they use a VAFM or a volume air flow meter which is sealed up and just uses a flap door to estimate the volume of air.
__________________
~Dale~
mt_goat is offline
Old 09-24-2007, 06:14 AM   #11 (permalink)
mine has a big sensor right on the air box. last time i didnt have it hooked up properly it did this. so VAFM or MAF, im gonna check it out, clean the injectors, and check for vacuum leaks.
__________________
1988 Toyota P/U 4x4
pioneer CD deck
31x10.50x15 BFG A/T
KC Daylighters 100W
rancho rs5000
Old 09-24-2007, 10:17 AM   #12 (permalink)
Send a message via AIM to skife Send a message via MSN to skife
check the vacuum line that goes into the fuel pressure regulator, its on the back of the motor if its a 22RE.
it could very well be a fuel pump though, i just replaced mine.
to whoever said the fuel pump is pumping at a really high pressure, your wrong.
the pressure is between 27-31psi.
when my pump went bad it would run and drive, but bog way way down and stuff. is the motor throwing any codes?
__________________
'92 toyota truck
22re, header, 5 speed.
3" body lift, 31" michilin tires
26mm torsion NIB(box of the truck that is)
needs some TLC clean body, i paied $400
skife is offline
Old 09-24-2007, 12:00 PM   #13 (permalink)
corvey's Avatar
30-45 psi fuel pump for fuel injection is very high compared to a carb'ed system. Compare the two and you will see it's at least 4x-10x PSI greater in most compared systems... If you put a fuel pump made for a carb system on a fuel injection system, it will not work!
He has already noted that he can rev really high, so fuel delivery is there, so it's not the fuel pump IMO...
__________________
corvey is offline
Old 09-24-2007, 10:00 PM   #14 (permalink)
i dont have a machine to read any codes, but it prob would read a code saying the cold start injector is not working, since i have it disconnected until i buy a new wiring harness and new sensors. any idea where i could buy a code reader? and what type should i buy? i know not obd1 or something...
__________________
1988 Toyota P/U 4x4
pioneer CD deck
31x10.50x15 BFG A/T
KC Daylighters 100W
rancho rs5000
Old 09-25-2007, 03:52 AM   #15 (permalink)
corvey's Avatar
Is your check engine light on? You can have it read for free at Autozone or Advanceauto.
__________________
corvey is offline
Old 09-25-2007, 04:24 AM   #16 (permalink)
mt_goat's Avatar
Quote:
They can't read pre OBDII vehicles, but he can do it with a paper clip. I can't remember which pins you stick the paper clip but its been posted on here before.
__________________
~Dale~
mt_goat is offline
Old 09-25-2007, 04:56 AM   #17 (permalink)
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
http://www.off-road.com/toyota/tech/codes/index.html
__________________
Matthew
Context is everything....
Quote:
Originally Posted by abecedarian View Post
freckles, shmeckles... that was your acne reflecting on my pearlescent skin.
Get smacked....join chat!
http://www.yotatech.com/misc.php?do=flashchat
thook is offline
Old 09-25-2007, 05:30 AM   #18 (permalink)
corvey's Avatar
^ sweet link Learn somthing new every day
__________________
corvey is offline
Old 09-29-2007, 05:44 AM   #19 (permalink)
ok there wasnt much wrong, my mechanic said my throttle body was a little dirty, and i DID have a vacuum leak. he did both. runnin like a champ now.. i just cant believe how much power it still has for 251,000 miles, i can burn rubber like no tomorrow with it if i truly wanted to. leavin da civics in shame. . ok, time to start replacing sensors and pumps anyway. call it '250,000 mile work/tuneup'. thanks to everyone on here who responded.
__________________
1988 Toyota P/U 4x4
pioneer CD deck
31x10.50x15 BFG A/T
KC Daylighters 100W
rancho rs5000
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
90 toy fuel pump ques. and fuel guage npreo1 Offroad Tech 1 05-23-2007 11:24 AM
Fuel line? Fuel pump? Fuel injector? MikeKaduce 86-95 Trucks & 4Runners 3 11-06-2006 07:21 PM
How long will a bad water pump last? calrockx 95.5-2004 Tacomas & 96-2002 4Runners 21 11-23-2005 05:52 AM
fuel pump? or fuel filter? retardedspleen Maintenance & Repair Archives 4 05-02-2005 07:14 PM
Symptoms of water pump going bad? DrummerDaveB 95.5-2004 Tacomas & 96-2002 4Runners 8 08-03-2004 12:51 PM
2009 InternetBrands, Inc.
