How many 3VZE miles you got???
#63
195k on the truck, 50k on rebuilt motor. The only problem I have is the constant exhaust leaks. I seem to go thru the doughnut gaskets between the manifold and down pipe, I replace them once a year. I'm going to start buying the cheap aftermarket one's instead of wasting money on the Toy one's.
#64
Originally Posted by AgRunner06
Quote:
Originally Posted by yotaluver
182,xxx on my 90 22re p-up and going strong (trany will not hold 1st have new one to put in just got to get to it)
This is a common problem with the 5-speeds. The bushing will wear out and the shifter will pop out of gear. I think it's like a $10 fix.
Check out this thread. You should find your answer there.
#68
Hi All,
I got a '96 4Runner 5VZ-FE Automatic 4WD....original transmission and engine...121,000 miles and still going. Just changed almost all the drivetrain fluids except for the front diff...which I plan to do along with my next engine oil change. I LOVE TOYOTAS!
#71
171k on my '98 V6. Please keep your fingers crossed for me--I have to drive it another 500 miles to have the timing belt/water pump replaced by my trusty mechanic... (it's never been done... MY FAULT.)
Poncho0206
07-10-2015 06:21 PM
Vargntucson
07-04-2015 12:15 PM
