how do i fix a high idle?
Old Dec 14, 2007 | 07:27 AM
cEElint's Avatar
hello all.. i'm new to Toyota pickups, well working on them anyways.. i come from a Honda background and my car recently got stolen..so i picked up a 91 STD shortbed and i noticed the idle sounded as it were higher than normal, there is no tach so its hard to tell.. is there a screw or something i turn on the MAF to adjust the idle??
also, i was wondering if there is any performance upgrades for these.. like intake or header .. possibly a cam or something.. any info appreciated.. TIA
-Clint
Old Dec 14, 2007 | 07:39 AM
yotaman90's Avatar
What engine does it have?
rdlsz24's Avatar
What engine do you have? If it's the 22RE 4-cylinder then there is a screw by the throttle body that you can turn to adjust the idle. If you still can't get the idle to lower when you have that screw turned all the way down, you may want to check your timing. If you have the 3.0 6-cylinder, then I don't know
Rob
Old Dec 14, 2007 | 07:41 AM
yotaman90's Avatar
The 3.0 also has an adjusting screw on the throttle body.
Old Dec 14, 2007 | 07:47 AM
rdlsz24's Avatar
Here I found this which should help you no matter which engine you have:
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Rob
Old Dec 14, 2007 | 08:25 AM
cEElint's Avatar
hey thanks for the fast replies guys.. its a 22-re.. i was looking and saw the screw on the throttle body.. its just like my Honda, kinda.. which way would i turn the screw to lower the idle..i'm guessing counter-clockwise
Old Dec 14, 2007 | 11:37 AM
notanymore's Avatar
yeah it should be, but if not just go the other way
Old Dec 14, 2007 | 11:42 AM
cEElint's Avatar
got that fixed.. rather easy...
Eggslinger
Jun 8, 2019 03:32 PM
kcaudill
Jul 20, 2015 12:06 PM
luckypig44
Jul 19, 2015 11:25 AM
kyletbert
Jul 17, 2015 11:39 AM
ZONAYODA
Jul 13, 2015 07:17 PM
