hi-beam question
hi-beam question
hey when u guys turn on ur high beams, does the passenger side light go to high-beam while the driver side go super dim?
mine does even after i switch the high / low beam wires around.
Is it a problem with a fuse or connector?
mmmkay, well it seems that on my lights
Normal
passenger: normal
driver: slightly dimmer
Highbeam
passenger: highbeam
driver: super dim (like an uber ultra lowbeam)
i switched the highbeam / lowbeam wires too on the driver side light and still the same
Normal
passenger: normal
Highbeam
passenger: highbeam
Track down your drivers side headlight ground! Its either loose, dirty, corroded, or some variation of those. It wouldn't hurt to clean up your passenger side ground either.
Could be the combo switch. Check out 4crawler's discussion of combo switch function and repair http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
pretty sure its not the switch, and its not the ground wire (unless i am missing it)
i dont really need to fix this to drive, its just an annoying nuance
TJWilly
07-31-2015 02:05 PM
