Help with what I need for rear disc conversion
Old 07-18-2014, 01:18 PM
jordanhere123's Avatar
Hello I am a little confused on what I exactly need for the rear disc brake conversion.
To start I have a 1994 22re pickup 4wd 5 speed.
Here is the bracket I am looking at http://www.ebay.com/itm/Rear-Disc-Brake-Brackets-Toyota-Mini-Truck-Pickup-4Runner-4WD-79-95-Conversion-/300878917633?pt=Motors_Car_Truck_Parts_Accessories&hash=item460dc7f001&vxp=mtr
What else I need
- 85 monte carlo or seville front calipers?
-brake pads for what ever caliper I go with
-rotors from a 6 lug chevy truck ( not sure what model or years will work )
-Unsure on the 2 lb residual valve or a 1" bore Master Cylinder.
-Also unsure on the proportioning valve.
I really appreciate the help
Old 07-18-2014, 03:59 PM
BigBluePile's Avatar
This may help:
http://www.4x4wire.com/toyota/reviews/rear_discs/
Old 07-18-2014, 07:12 PM
Longo118's Avatar
Not to be a d*ck, but what about the rear disc brake conversion kits they sell for a couple hundred bucks, it comes with literally everything you'll need. Instead of trying to collect the right parts to do it.
Old 07-18-2014, 07:22 PM
I looked Into the complete kits. Who offerers the best complete kit for the money? Also I noticed I still need to do something with gettingthe 2 lb residual valve or a 1" bore Master Cylinder and a proportioning valve?
mm3lee's Avatar
low range off road has a bracket kit that will utilize 85 front rotors and calipers. I like the idea of not having to modify rotors or pay to much for it to have it all ready done. yes they are a solid rotor verses a vented rotor but it is for the rear and even some new cars still utilize a solid rear rotor. you will at that point use a 4 piston caliper verses a crappy slide bolt single piston set up. yes the work but open to issues.
Old 07-18-2014, 07:34 PM
http://www.lowrangeoffroad.com/yotamain/4runner/brakes/toyota-rear-disk-brake-economy-kit-tdb-400.html
So just calipers and rotors I need for this? Which can be bought for not that much I'm sure .
Old 07-18-2014, 07:43 PM
Also I seen this
http://www.davezoffroadperformance.com/store/suspension/brakes/tg-rear-disc-brake-kit.html
Old 07-19-2014, 09:47 AM
osv
osv's Avatar
the problem with these rear disc kits is that no one seems to have a decent parking brake solution.
Old 07-19-2014, 10:08 AM
Yeah I know. That's disappointing.
Old 07-19-2014, 12:45 PM
donomite49's Avatar
all pro offroad has a transfer case mounted disc E-brake kit(gear drive TC).
i've had the trail gear kit for a while now that i'm happy with.
you will need to do the 1" mc but you can use the stock proportioning valve.
i still need to install my willwood proportioning valve and get a dual diaphram booster.
coleypull15
11-03-2015 07:41 AM
BeMiceElf
10-10-2015 09:40 PM
09-04-2015 09:27 AM
jaretstuff
08-04-2015 02:08 PM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: Help with what I need for rear disc conversion
