help help overheating still
Old 05-22-2010, 07:42 PM
tundratrucker's Avatar
hi i have a 92 22re i have replaced head gasket ,waterpump, thermo,hoses,cap and it sill overheats when driving and when ideling
Old 05-22-2010, 08:12 PM
bend's Avatar
Have you used any stop leak for sealing a bad head gasket?
Old 05-22-2010, 08:14 PM
BigBluePile's Avatar
Welcome to Yotatech!!!!!!!!!
Is your radiator clogged?
Old 05-22-2010, 08:17 PM
adamsbro1's Avatar
Make sure you got a good thermostat and or the right one!! Then check radiator and heater core for cloggs. Heater core hoses one should be hotter than the other!
i havent , but i dont kno i bought this truck it was overheating it would not overheat when idling, just driving, but when i changed the hg it started overheating all the time
Old 05-22-2010, 08:19 PM
bend's Avatar
That would be the OEM thermostat. Don't buy one from the parts store. Buy one from the dealership or 1sttoyotaparts.com. I think they are only like 5 or 10 bucks
Old 05-22-2010, 08:30 PM
the radiator is the only thing not new , but itseems to have good flow , put water hose in it and it flowed out , should it flow as fast as a water hose ????
Old 05-22-2010, 08:35 PM
adamsbro1's Avatar
Check the heater core!!!! If your not losing fluid and it's overheating it's gotta be a clog or a thermostat!!! And I agree about the thermostat get it from Toyota!
Old 05-22-2010, 09:12 PM
the heter core is bypassed and the thermo checks out fine ..im at my wits end.......
no smoke no leaks , i can see the water flowing when i rev the motor , it may be time to move on
Old 05-22-2010, 09:22 PM
adamsbro1's Avatar
Don't ever give up on a yota cause they don't give up on you! Have you checked the temperature sensor to make sure it it TRULY overheating???
Old 05-22-2010, 09:30 PM
adamsbro1's Avatar
You say thermostat checks out fine?? How are you checking it???
Old 05-22-2010, 09:44 PM
I put It in boiling water and the water is flowing , and it's def overheating it starts tomake boil sound
Old 05-22-2010, 09:51 PM
adamsbro1's Avatar
In my experience that will ruin a thermostat because boiling is 212 degrees and it's probably supposed to open around 180ish. Try pulling the thermo out and bolting it up without the thermostat in then run it that will make the coolant flow straight through and not give it a chance to warm up. If it's still overheating then I would say your waterpp isn't pumping as much as it should and letting the coolant sit in the block to long!
Old 05-22-2010, 10:13 PM
the water pump is new , took the stat out and still heats up to high , must be as clog , but the radiator seems to be circulating good who knows...
Old 05-22-2010, 10:20 PM
adamsbro1's Avatar
Ok I understand the waterpump is new but no offense it could still be junk!! Hat about the radiator does it have any damage noticeable if it has flow but a bunch of fins smashed or some tubes pinched it could cause that!
Old 05-22-2010, 10:23 PM
adamsbro1's Avatar
Also you could have some tubes clogged so the fluid isn't getting through enough tubes! If it doesn't look damaged try pushing water through it from bottom up/ backwards to help possibly push any junk in out!
Old 05-23-2010, 06:26 AM
swampfox's Avatar
is it pulling air thru the radiator ? the fins could be plugged. i have seen it happen alot with farm trucks. also check the condenser if it has one ,the radiator could be clean and it could be stopping air flow.
Old 05-23-2010, 08:02 AM
Team420's Avatar
Are you sure you got ALL the air outta the system? An air bubble in the system will make it overheat.... If its not air in the system... gotta be the t-stat, or clog somewhere in the system.....or a bad h/g install....
ladybugRC
458
08-21-2020 10:41 AM
Corvoid
12-11-2015 11:21 AM
alexcarey
10-14-2015 06:05 PM
larrys93pickup
09-17-2015 07:05 PM
LotOMiles
09-14-2015 11:45 PM
Quick Reply: help help overheating still
