help, broken head bolt
Old 05-09-2015, 01:29 PM
Josh_Br's Avatar
Hi,
Is there any hope for getting this out? Any good ideas? Thank you
Old 05-09-2015, 02:06 PM
nacheswheelin's Avatar
Not to familiar with 22rs but im assuming its the big stud? Spray it with pb for about a day or so. Theres also the new wd 40 line that should also work. Then vice grips should do. They also make bolt extractors. Ive never had luck with the cheap sets though. Then there are ez outs if its broken flush. Same deal dont buy the cheap set. Just spray it a few times first though. They try to extract preferably with vice grips then if that wont work spray again and maybe try a little heat to the stud. If you dont get it worst case drill and retap very carefully.
Old 05-09-2015, 02:11 PM
millball's Avatar
Penetrating oil, rap it on its top with a hammer, work it back and forth a bit with vice-grips.
Old 05-09-2015, 03:12 PM
scope103's Avatar
The tool designed for that purpose is a stud extractor (e.g.,
Amazon.com: Powerbuilt 648639 1/4" to 3/4" Stud Extractor: Automotive Amazon.com: Powerbuilt 648639 1/4" to 3/4" Stud Extractor: Automotive
) But since you have so much sticking out, I would probably start with the vise-grip route. Consider using two (opposing, so that you use two hands) so that you have only torque (rotating) and little bending. You DEFINITELY don't want that bolt to break off.
Old 05-09-2015, 04:42 PM
Josh_Br's Avatar
By God's grace, some fancy WD40, and a big pipe wrench, I got it out. Thanks for your ideas. I thought it'd be in there for good.
Old 05-09-2015, 07:31 PM
Good to hear that new wd40 is some good stuff.
kgcwb44
01-29-2023 10:02 AM
dumpster84
04-30-2016 06:03 AM
09-04-2015 09:27 AM
whereAreMyPants
07-22-2015 03:32 AM
jon.r
07-11-2015 03:34 PM
Quick Reply: help, broken head bolt
