help - 92 3.0 losing minimal coolant
Got a 92 3.0 v6 truck with 248000 miles. Using coolant and not smoking white and not getting into oil. Passenger floor board is dry so rule out heater core. Can smell a burning smell and what smells like oil but barely using any. Considering maybe a water pump? No power loss and fuel mileage is at 18 mpg. Seems to be running fine but using coolant. Need help with this. Thanks
There's a coolant line that goes through the throttle body near the bottom. In other words, near the valve cover. Is that where you see coolant?
There's one that goes from the water inlet in front between the heads to the "water bypass outlet" in the back. Localizing your leak (front, right, back ...) might help point where to look.
Looks like coolant is on both sides but more towards rear on both sides but higher up from head gasket. Looked around rear lines back of engine and can't see anything.
Can you post up a pic or two? I'm having a hard time thinking how coolant can come out of the VC gaskets.
As mentioned earlier, it may be coming out of It could be the coolant bypass tube that runs between the cylinder heads and filling the valley with coolant.
Yeah but hose broke off above clamp. Now gotta cut away rubber to get to clamp...what a messed up angle. Hate these clamps. There was a pool of coolant below hose connection.
The correct molded hose, rather than just a piece of straight hose jimmied in, will work better. Not cheap, but consider how you'll feel when it's REALLY cold and the heat doesn't work.
http://www.toyotapartsoverstock.com/...rimLevel=18380
FS[PacSouthWest]: 1988 4runner $1500
4x4-runner
08-03-2015 07:14 PM
pyramid
07-29-2015 06:53 AM
the1998sr5
07-16-2015 06:20 AM
