HELP!!! 87 22ret wont idle
Old 05-09-2007, 06:12 PM
littleredtoy's Avatar
I have a 87 4runner 22re turbo that wont idle. Ive replaced the pvc valve, checked the timing, checked the tps, no trouble codes, a new distributor with a new cap and rotor, new spark plug wires, new spark plugs, and all the lines are on with no leaks, and it has fuel pressure. The only thing it can do is stay running at about 2000 rpms and then at idle it will just die. Ive been working on this thing for about a month and still cant find the problem. Can someone please help me.
Old 05-09-2007, 07:29 PM
Bill's Avatar
seeing that you replaced the rotor cap, did you get the wires in the right spots?
When I got my motor together I had the #2 and 3 wires on backwards. I could start the truck and it would run with some throttle, but it would die at idle.
Have you checked the turbo? If it is starting to seize up that may do it: blades not spinning properly at idle, so no(or just not enough) air is getting into the motor.
Old 05-09-2007, 07:33 PM
toyaholic's Avatar
check your air flow meter.
Old 05-10-2007, 12:25 PM
All the wires are in the right spots and i swapped the air meter with my other 22re air meter and it did the same thing.
Old 05-10-2007, 12:31 PM
keithguts's Avatar
Might want to change your gass filter as well, and do a sefoam treatment. Just and Idear.
Old 05-10-2007, 02:19 PM
tampabayota's Avatar
its the pvc valve i bet ya! truck wont run right with a pvc valve going bad
Old 05-15-2007, 10:58 AM
Its got a new pvc valve and gasket, and we replaced the fuel filter about 500 miles ago with sea foam every 4 tanks since then.
Old 05-15-2007, 11:51 AM
dcg9381's Avatar
It sounds like you've done a lot on the ignition side...
Have you checked the basics - IE compression?
What about fuel? Is it going lean when it dies? Rich? (maybe probe the narrowband output)
Old 05-22-2007, 07:27 PM
did a compression test, but ill see whats up if its lean or rich ill tell you when i get done.
Old 05-22-2007, 09:44 PM
TC22RE's Avatar
There's a high chance that your throttle body is dirty, which is causing idle air problems. Using some carb cleaner and a rag clean out your throttle body (with the engine off of course). See if that helps clear up your problem. Make sure you clean it out well, open the throttle and clean as far into the throttle body as you can get your fingers. GL!
Old 05-23-2007, 08:46 AM
ToyotaGuru's Avatar
Test
Make sure the The throttle bodies vaccum lines are working.
The FSM says who to check them. They usually get clogging
before the TB since the ports are really small, use a small stiff wire.
However, the problem sounds more mechanical.
Check the compression, make sure a valve is not bent.
Blamalam
03-12-2022 07:34 AM
Marsheen
02-17-2016 12:29 PM
GrimWolf
08-28-2015 03:36 AM
noosh
08-21-2015 03:49 AM
Sarcazmo
08-15-2015 08:22 PM
Quick Reply: HELP!!! 87 22ret wont idle
