heater fan only blows on low
The blower switch connects through the blower resistor to the motor. On highest speed, it connects direct to the motor. Since yours works on at least one lower speed, the problem is probably not in the resistor, but in the switch itself.
Testing the switch will be easier if you use the schematic. Which will be easier to find if you know the year/model of your truck.
The blower resistor is a set of high-power resistors connected so that on low speed setting, the most resistance is in the circuit causing a low speed on the fan. Each higher speed selection from the switch bypasses a resistor which in turn lowers the resistance in the circuit resulting in higher blower speeds until you hit the top speed 3 or 4 depending on some things, where there is basically no resistance and the fan blows as hard as it can.
The resistor is located behind the "glove box", and is mounted to the firewall. It's a little awkward to reach but otherwise pretty easy. If it has issues, a simple visual inspection will reveal those: burnt resistor wires are easy to find there.
And, you'll need to pull the resistor to check your switch wiring since the switch connects to the resistor.
Check the simple stuff first. Pull the switch out of the dash and look at all the contacts. Make sure they are clean. Mine failed because the contacts were dirty. After cleaning them the blower motor worked again. If the switch is good check the resistors.
well i took a look, and i could find the resisters but when i turn the fan on low i herd it click on then went to mid and no click dos this help in any way
The connector in my dash to my switch was physically burnt/melted. I had to rewire everything.
Switch was fine and the typical low setting was fried on my resistor
the1998sr5
15
07-14-2020 08:35 PM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
94 Newbie
08-06-2015 10:33 AM
