headlight issue
Old 10-09-2011, 04:16 PM
behemoth421's Avatar
headlight issue
my highbeams do not work, but my low beams do. now if i FLASH my high beams * pull back on lever they work but if i flip the lever to highbeams they wont come on. is there anyway i can just wire up a toggle switch for the highbeams?
thanks
joe
Old 10-09-2011, 07:04 PM
combatcarl's Avatar
Nah, don't do all that, man. Search around on here, or better yet, google your problem and it'll probably come right back here somewhere. Mine were doin that too, but intermittently they would just not work for 5 seconds, then come on. Ya gotta pull your wheel off, get into the switch back there and clean the contacts. It's pretty painless. Scale of 1-5, maybe 1.5.
Old 10-09-2011, 07:15 PM
jsn_stockard's Avatar
If cleaning the switch doesn't fix it replace it. They aren't too expensive
john4wd's Avatar
X2 combatcarl, I had to do that when I had my 87, easy peasy!!!!
Old 10-09-2011, 07:16 PM
yotes86's Avatar
should have no issues finding a replacement
Old 10-09-2011, 10:17 PM
combatcarl's Avatar
4crawler's website. That's where this and google led me. Guy's done about everything to a Toyota that can be done.
Old 10-10-2011, 02:22 AM
daved5150's Avatar
Check this link out:
https://www.yotatech.com/forums/f115...roblems-80882/
I had a problem with the headlights on my 88 4Runner at least a year ago, prob two. I believe this is the thread that I used to help me. I took apart what misterzee was talking about and soldered it solid. Fixed the problem. If this doesn't do it for you, go to the General Electrical & Lighting Related Topics and search for "headlight problems." When I searched that, it came up with 31 results. Good luck.
Old 10-10-2011, 04:04 AM
TNRabbit's Avatar
There is an easier method you can try first:
Get a can of Caig DEOXIT & spray the switch liberally-- work it every way for a minute or so, then let it dry 5 mins & try it again. That stuff is like liquid GOLD for electrical contacts!
Old 10-10-2011, 07:02 AM
svdude's Avatar
As stated above, it's most likely your dimmer switch in your steering column. To test it, get a multimeter and do a continuity test between pins 5 and 13 on the big plug just under the steering column. You should have continuity when your high beams are either "flashed" or on. If you have continuity when flashed but not when on then it's dirty contacts inside the relay. It takes about 5 minuets to pull it off and clean it up.
Old 10-11-2011, 08:40 AM
yotarover's Avatar
no kidding that's why i have confidence in buying messed up hack job yota's
Old 10-11-2011, 05:27 PM
thanks everyone for the replies. i will look at it tomorrow
ghostmoney
01-28-2018 11:42 AM
09-04-2015 09:27 AM
mldave
08-10-2015 09:23 AM
rushw
07-18-2015 01:46 PM
icentropy
07-14-2015 10:23 AM
Quick Reply: headlight issue
