Headlamp vertical adjustment part
I have been trying to adjust my '92 4Runner's right headlight but it seems as if the piece that adjusts it is broken (the plastic threads are stripped). Does anyone know if this part can be ordered? I just looked at the headlamp diagram but I can't see any of the adjustment parts listed. Thanks in advance,
- Paul
- Paul
This is the kind of part that you can find in the "miscellaneous parts" section of your local auto parts hut. (A prolific manufacture is Dorman.)
The real Toyota part may be best, but you can carefully remove the non-functioning plastic part and walk it down to your local store to match it by eye. While you're at it, disassemble the whole assembly, make sure all the sheet metal is bent the way it was when it came from japan, and replace both screws just to be sure.
check a junk yard, the adjusters from many years and even the horizontal adjusters should fit, im pretty sure if they got any toyotas they should have atleast one adjuster, theres 4 per truck or do like I did before I got a new one, just get out and adjust it by hand
