Headlamp housing replacement
Old 12-19-2006, 04:54 PM
Remko-'s Avatar
Lightbulb Headlamp housing replacement
ive done a search and read alot of threads about changing the headlight housings out for hella/ipf H4 housings, is this possible on a 1993 4runner? i went to canadian tire to get a set of sylvanias but the clerk told me that i can only replace them with oem toyota units. also what is the difference between H4 and 9004 bulbs? is there any perfomance gain or is it just the type of connector?
Old 12-19-2006, 05:01 PM
4Crawler's Avatar
Look at the back of the lamps:
http://www.4crawler.com/4x4/CheapTri...l#HarnessTypes
H4:
9004:
If you have a ~5"x7" retangular housing, then the swap is a piece of cake:
http://www.4crawler.com/4x4/CheapTri...adlights.shtml
Old 12-19-2006, 05:26 PM
Remko-'s Avatar
I understand that there is a differance, but are H4 bulbs better?
and i dont have just a 5x7 housing it looks more molded to the shape of the front end.
Old 12-19-2006, 05:35 PM
4Crawler's Avatar
If you have the molded housing, likely you have the 9004 lamps and you are sort of stuck with the housing you have. Might be some sort of option for converting those housings, but not familiar with them. For ease of swapping, you want to keep the same type of lamps as the connectors you currently have. That way you can just plug in new bulbs and be done. No real difference in H4 and 9004 bulbs, they are both available in various wattages, colors and what not. 9004 is probably a superior type of conector, being somewhat more sealed, H4 bulbs are probably less expensive since they are more commonly used.
Old 12-19-2006, 06:13 PM
Remko-'s Avatar
awesome, thats exactly the clarity i was looking for.
Thank's
Old 12-21-2006, 05:39 AM
Babypig's Avatar
You can get them at Cambodian Tire. They are Bosch units and are in the driving light section. Don't go by what they tell you cause they usually don't know. I have only been able to find them in pairs is the problem. Where abouts in Canada are you?
Regency
20
01-03-2020 07:43 PM
andrewtexas123
07-14-2015 04:29 AM
A2theK
07-12-2015 10:46 AM
Poncho0206
07-10-2015 06:21 PM
Edionne13
07-09-2015 01:59 PM
Quick Reply: Headlamp housing replacement
