Have I missed anything to swap 22R engine from 1985 2x4 in to my 1987 22R 4x4?
Today I went to the parts house to see what it was going to cost me to swap engines putting my 1985 22R out of my 2x4 PU in to my 1987 4x4 PU which has the 22R engine also. Both trucks have manual 5 speed G-52 transmissions. Please someone correct me if I am wrong about the changes I see that I need after I pull engines.
I.) Swap oil pans install new gasket
2.) Replace exhaust doughnut between manifold and exhaust system.
3.) Replace gasket at back end of EGR system manifold.
4.) Possibly replace front oil seal on old transmission
5.) Possibly replace fluids in tranny and differentials.
6.) I need to replace the Power steering feed hose from reservoir to pump.
Have I missed anything? My 85 engine is excellent shape and only needs oil pan swapped to clear front drive assembly.
I look forward to your response, If I am right about this , m engine swap should cost like $50 including fluids.
grey
grey
grey
grey
grey
Staff
You will need to oil pick up tube that is inside the pan which it looks like you mentioned along with the oil pan but I am sure that is the biggest part. Looks like you got everything covered that I can think of right off. I am not sure if the dipsticks are different or not.
grey
91toybeater
12-27-2015 07:46 PM
Eagle564
06-23-2015 11:29 PM
TheManOutside
06-18-2015 03:32 PM
JaredL
06-16-2015 04:47 PM
