harmonic balancer replacement gone wrong. 22re
Old 07-21-2014, 05:49 PM
rowdyota's Avatar
So last friday I went to replace my harmonic balancer. Read up on it finding out everything I could. Went to pull the main bolt out and sheered it off in the crank. Currently have the bolt drilled through with a 7/32" drill. Just workin on gettin the bolt out.
harmonic balancer replacement gone wrong. 22re-forumrunner_20140721_203909.png
Attached Thumbnails harmonic balancer replacement gone wrong. 22re-forumrunner_20140721_203858.png   harmonic balancer replacement gone wrong. 22re-forumrunner_20140721_203933.png   harmonic balancer replacement gone wrong. 22re-forumrunner_20140721_203959.png   harmonic balancer replacement gone wrong. 22re-forumrunner_20140721_204011.png   harmonic balancer replacement gone wrong. 22re-forumrunner_20140721_204045.png
harmonic balancer replacement gone wrong. 22re-forumrunner_20140721_204102.png   harmonic balancer replacement gone wrong. 22re-forumrunner_20140721_204507.png   harmonic balancer replacement gone wrong. 22re-forumrunner_20140721_204727.png   harmonic balancer replacement gone wrong. 22re-forumrunner_20140721_204805.png
The following users liked this post:
Donald Duncan (06-03-2020)
Old 07-21-2014, 07:14 PM
rworegon's Avatar
What was your method for breaking the bolt loose and ultimately shearing it?
Old 07-21-2014, 07:17 PM
rowdyota's Avatar
I used a breaker bar and so He-man strength. It looks like that bolt was over torqued with no anti-seize or lube when installed
Old 07-21-2014, 07:22 PM
scope103's Avatar
The bolt is steel-on-steel so I'm not sure why one would use "anti-seize." Lube SHOULD be used, but principally so that it will torque correctly, not to make it come out easily. If it was tightened with a big-ass 1" Ingersoll-Rand impact driver (instead of a torque wrench) it could certainly have been over-torqued.
How did you keep the crank from turning while applying He-man strength? I doubt that contributed to the bolt shearing, but I'm always curious.
Old 07-21-2014, 07:26 PM
rowdyota's Avatar
I just put it in 5th gear and ebrake on. Keepin it pretty still.
Old 07-21-2014, 07:34 PM
rowdyota's Avatar
And as far as anti-sieze or any lube for installation I have always been taught that unless it specifies dry torque to always use wet torques. No matter what material
mskalmus
05-28-2017 07:51 AM
MMA_Alex
25
04-18-2017 05:07 AM
smiley52
07-11-2015 05:16 AM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: harmonic balancer replacement gone wrong. 22re
