guide to removing plenum in 94 4runner 3zve 3.0 v6 4x4?
Old 12-04-2013, 12:01 PM
mattesonb's Avatar
I have looked all over the net and the forums and i cant seem to find a clear guide to removing the upper plenum (i need to replace the fuel line)
is there anyone that can help or perhaps explain step by step so i dont do something out of order?
Old 12-04-2013, 12:57 PM
scope103's Avatar
http://personal.utulsa.edu/~nathan-b...68cylinder.pdf
This is actually for removing the heads, so some of the steps (like removing the exhaust connector) are beyond what you need to do. But it should be obvious.
I would advise getting a piece of paper and simply diagramming each vacuum line (and hang onto that paper, you'll want it in the future). Tape is good, photos are good, but a diagram is unambiguous. I'd also advise getting a hair dryer (or a heat gun if you're careful) to gently warm some of the larger rubber hoses. The PAIR hose in the aft left corner is about 25mm; a little warmth will make it much easier to wiggle and release.
Old 12-04-2013, 05:06 PM
mattesonb's Avatar
you are a lifesaver! thank you so much!
83yotastockR
11
11-10-2015 06:54 AM
Jdgarrison
10-01-2015 05:22 PM
Jdgarrison
10-01-2015 02:11 PM
hiluxinargentina
09-30-2015 05:51 PM
charlie_fong
09-27-2015 10:06 PM
Quick Reply: guide to removing plenum in 94 4runner 3zve 3.0 v6 4x4?
