guess what, anopther 22re running bad!
Old 08-20-2009, 06:02 AM
Robert m's Avatar
so to set the timing chain back to where it was before can i just take the cam sprocket loose and move it back a tooth then reinstall or do i have to take the whole front of the engine apart to get access to reset the timing chain?
Old 08-20-2009, 06:12 AM
Lumpy's Avatar
It's going to be a pain but I think you can jump a tooth just by removing the valve cover. You will have to removed the sprocket but I think they'll be room to move it.
Can't help but to think about...
Spacely Sprockets
and the local rival Cogswell Cogs
Old 08-21-2009, 02:30 PM
Robert m's Avatar
just got off the phone with engnbldr and he said basically the same, to put it back the way it was and to check the distributer. if that still doesnt get it right, to then look at the adjustable sprocket from L.C. or to take a dremel to the distributer slot and extend it a little more to get the timing where it needs to be. that dude knows way too much about these engines off the top of his head. i will have pics of how the chain was to how it is now once im done with changing.
Old 08-21-2009, 02:57 PM
abecedarian's Avatar
Is the little "shim" or "washer" there between the cam sprocket and the distributor drive gear?
I don't have a pic of it but you'd know what I mean if you looked. There should be an approximate 1/10" shim between the cam sprocket and distributor drive gear.
If you don't have it, you'll never get the distributor in the right 'tooth' to have sufficient range to adjust the timing and may hurt the distributor itself.
Old 08-21-2009, 04:51 PM
  #25
Robert m's Avatar
i dont think i have a washer there..... $%^$@#$%
here are the pics
before
after
Old 08-21-2009, 04:55 PM
  #26
a pic "after" looking straight down would be nice.
and no need to start another thread for this: https://www.yotatech.com/forums/f116...ibutor-189722/
Old 08-21-2009, 04:59 PM
  #27
Robert m's Avatar
engine is all back together so a pic of one looking down isnt possidle right now but i know there was not a shim in there.
Old 08-21-2009, 05:58 PM
  #28
Robert m's Avatar
ok, so i took it back apart and maybe i do have that shim in there but, i have a new problem that i just found. look at the relation to the dot on the cam sprocket to the line on the crank pulley. there supposed to be lined up light?
Old 08-21-2009, 05:59 PM
  #29
Originally Posted by Robert m
after
and the shiny link on the chain still doesn't line up?
Old 08-21-2009, 06:11 PM
  #30
Robert m's Avatar
is that supposed to be in the middle?
Old 08-21-2009, 06:43 PM
  #31
Robert m's Avatar
so im beginning to think the guy who set this engine up did it wrong. isnt the crank pulley timing mark supposed to line up with the dot on the timing chain sprocket?
Old 08-21-2009, 06:52 PM
  #32
yeah, the dot on the crank sprocket should line up with a dot on the chain, just like the dot on the cam sprocket should like up with a dot on the chain as well, at the same time.
Old 08-21-2009, 07:08 PM
  #33
Robert m's Avatar
ok so in theory the dot on the cam sprocket should be inline with the notch on the crank pulley correct? which means if i rotate the engine by hand and set the crank pully notch to the 0 on the timing cover and then set the cam sprocket dot to the 12 o'clock position everything should be lined up correctly? is there anyway to see if the guy who did the install did not align the crank sprocket dot with the shiny link on the chain without tearing the front of the engine apart? i think thats is the whole problem.
Old 08-21-2009, 07:12 PM
  #34
nope.
You will have to remove the timing chain cover, verify the bright link on the chain is in line with the dot on the crank sprocket then put the dot on the cam sprocket in line with the bright link on the chain....
Old 08-21-2009, 07:33 PM
  #35
Robert m's Avatar
and hope that when i cranked it over and it clunked, that wasnt the valves hitting the pistons, even though i think it was.
Old 08-22-2009, 01:05 PM
  #36
Robert m's Avatar
ITS ALIVE!!!!!
after taking an 8 hour break from trying to put this thing back together yesterday, i started fresh this morning and i finally got it to fire and run. i was really afraid that i had bent a valve but i took a gamble and the advice bleeder gave me and got it running. it purrs pretty good but i need to adjust a valve or two. a big thank you to Bleeder and Abe for help whether it was in PMs, this thread, or a different one. if i ever meet you guys the first round is on me.
moral of the story, if it aint broke, dont fix it.
forgot to add, the timing chain sprocket is now set to how it was originally. with it being a complete tooth off.
mskalmus
05-28-2017 07:51 AM
steve miller
10-10-2015 01:40 AM
MTLroadierunner
07-06-2015 12:17 PM
karbin
07-05-2015 11:37 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: guess what, anopther 22re running bad!
