Grelims in my truck!
Old 02-01-2011, 01:13 PM
adh_ff's Avatar
A few months back I put a 22RE engine out of a 92 pickup(auto) into a 84 4x4(manual). Was using it to make firewood out in the woods and everything was working great until a few days ago.
What is happening is whenever I get into a hard pull going forward the EFI fuse burns out. However, when I go in reverse through even harder pulls everything works as it should. I tried putting it into gear and holding down the clutch and raving the engine and no burned out fuse. There are no wires that are connected to the transmission or the clutch.
Any ideas?
Old 02-01-2011, 02:24 PM
ttrmike's Avatar
Check the wires in the efi harness for chaffing and shorts.
When you're going forward, it would cause unsupported wires to swing backwards. Maybe contacting another wire, or the firewall and causing an electrical short.
But going in reverse would casue the same unsupported wire to swing forwards. Away from simething like the firewall.
Thats were I would start atleast.
duckhead
170
11-13-2017 06:07 AM
MadMax48
07-03-2015 08:26 AM
thelifeadventure
07-02-2015 03:09 PM
Crazy_Guy97
12
06-24-2015 04:02 PM
Quick Reply: Grelims in my truck!
