Glowing exhaust
Old 09-23-2009, 05:56 PM
Romans117's Avatar
Glowing exhaust
New long block 22re. Bored .20 over, new head, turned cam, valves new or ground. Timing is set at 4 to lower idle to 900 rpm with jumper wire. Knock sensor is the only code. Great power. Runs smooth. No cat. Exhaust is flowing great. Injectors done by witchhunter two weeks ago. TPS has been adjusted. Egr good to go.
In other posts I read about the timing causing a red manifold, if the knock sensor is causing a check engine light it may effect the ECU's management of the timing advance. Is this accurate?
Old 09-23-2009, 07:13 PM
Jay351's Avatar
you are probibly running lean...
Old 09-23-2009, 07:18 PM
iamsuperbleeder's Avatar
personally, I'd install a new knock sensor, then go back and readjust your timing, cause I can almost garantee that bad sensor is throwing EVERYTHING off...
if the glowing exhaust persist after that, then you can start guessing at parts, lol. just fix what you know is broken first
Old 09-23-2009, 09:30 PM
RMP8080's Avatar
Where and when is this happening, when I drive on the beach my exhaust glows. Of course at night when it's dark...........
Old 09-24-2009, 04:16 AM
Romans117's Avatar
The motor has 35 miles on it. Night time.
Old 09-24-2009, 11:28 AM
well I bet it glows during the day time too, you just can't notice it
Old 09-24-2009, 11:47 AM
mokancraig's Avatar
I'll agree, either you're running lean or your timing is retarded.
Steven.m.paulk
06-07-2020 10:45 AM
the_supernerd
10-01-2015 09:20 PM
voiddweller
09-28-2015 11:21 PM
Keithstoyota
09-27-2015 07:29 AM
Quick Reply: Glowing exhaust
