Getting stuck in 4Lo...?
Old 06-15-2008, 12:46 AM
T-1000's Avatar
OK, I don't have an owner's manual, but shouldn't a 4Runner shift out of 4Lo when you it into 4Hi, or do you have to shift back to 2WD to get out of it?
Every time I try to get out of 4Lo and back into 4Hi it doesn't work, or at least it seems like it doesn't. The revs stay up and I get that cool whining sound, like a synchro in a standard spinning up kind of sound.
Old 06-15-2008, 04:29 AM
blueyoda's Avatar
It should come out of four low as soon as you pull down on the transcase stick. some times it takes a little movement, try shifting at 1-3mph it should help. You might need new oil in the tcase too.
Old 06-15-2008, 04:55 AM
CJM
CJM's Avatar
Put truck into neutral or push clutch in-then do it.
Old 06-15-2008, 06:24 AM
blueyoda's Avatar
I just assumed you were in transmission neutral.
Old 06-15-2008, 10:25 AM
1990Runner's Avatar
i dont know that sounds weird, is it a 5spd? is it stuck in 4-lo or will it go into 2-hi? cause on my brothers T 100 the snap ring holdin the shifter on came off and it was stuck in 4wd
Old 06-15-2008, 12:55 PM
SwampThing's Avatar
Roll a little forward, then roll a little back. Sometimes things will get bound up, and this'll help to get it back into 4hi from 4lo, or back into 2hi from 4hi.
Old 06-15-2008, 01:22 PM
T-1000's Avatar
It's an automatic. I'll try that stuff next time I'm out, thanks for all the suggestions
Old 06-15-2008, 01:41 PM
T-1000's Avatar
***Sorry for the double post, my computer is retarded.
Old 06-15-2008, 04:43 PM
T-1000's Avatar
This seems like a good time to ask since I don't have a manual...
What is the limitations for 4Lo? Like top speed and max shifting-into-it speed and all that?
Old 06-15-2008, 06:05 PM
Luvmeye22re's Avatar
To shift in 4lo you definitely do not want to be moving, and I'm pretty sure you want the auto trans in nuetral when you do it.
Old 06-15-2008, 06:36 PM
FredTJ's Avatar
Originally Posted by T-1000
<SNIP>
It's not your "retarded" computer, it's whatever the hell is going on with the underpinnings of this forum.
I suspect it's the MySqueelLikeAPiggy "database" that they use
Fred
Old 06-15-2008, 06:40 PM
abecedarian's Avatar
Fred
MySQL?:
hate to say but dotnetnuke (even running on Mono) and sqlexpress 2005 would do better.
Old 06-17-2008, 02:45 AM
SwampThing's Avatar
Originally Posted by abecedarian
MySQL?:
Hah, I'd never admit it to anyone except on an online forum, but I know exactly what your taking about. Who says rednecks aint go to college!
Woot 1,000th post.
Redeth005
06-28-2018 08:16 PM
rubrsidedwn
07-07-2016 07:28 PM
spiewaker
12-16-2015 01:10 PM
BK2TFUTURE
10-11-2015 08:42 PM
Obmi
09-24-2015 08:10 AM
Quick Reply: Getting stuck in 4Lo...?
