Fuel problems
Old Sep 6, 2008 | 05:36 AM
nolimit's Avatar
Fuel problems
Okay people I need some suggestions. !988 3.0 rebuild. First I got it back together and had oil presure problem. New oil pump was bad. Now that that problem has bee solved. I have the motor back in and everything seems to be checking out alright but no fuel. I have good fire to the plugs,checked the relay inside the left kick panel and it's operating the solenoid resistor checks out . Is ther anything I should check before dropping the tank to check out pump. Thanks
Old Sep 6, 2008 | 06:09 AM
mt_goat's Avatar
Do you have the AFM connected and the tubing in place? The flap door in the AFM turns on the fuel pump as air is sucked through it.
Old Sep 6, 2008 | 07:14 AM
nolimit's Avatar
I have it connected but not to the throttle body. do I need connect the whole air intake system. Thanks
Old Sep 6, 2008 | 07:18 AM
mt_goat's Avatar
Yeah, without the connection to the TB the AFM flap won't get sucked open to turn on the fuel pump. 11th commandment: Thou shall have no air leaks between the AFM and the engine.
Old Sep 6, 2008 | 07:26 AM
nolimit's Avatar
Thanks Goat I'll try that.
Old Sep 6, 2008 | 11:26 AM
nolimit's Avatar
Okay everything is hooked up still no fuel. Anything else I might try before dropping the fuel tank to check pump. Thanks
Old Sep 7, 2008 | 09:47 AM
nolimit's Avatar
Still have problems. This a 1988 4x4 truck 3.0 I've done more checking and don't think I'm getting juice to the fuel pump all the wiring looks fine. What else should I be checking I feel like it's something obvious. Please help
Old Sep 7, 2008 | 10:16 AM
mt_goat's Avatar
Does the flap move ok in the AFM?
Old Sep 7, 2008 | 10:45 AM
nolimit's Avatar
Yes everything seems to be operating
Old Sep 7, 2008 | 02:34 PM
abecedarian's Avatar
all your fuses are good?
Old Sep 7, 2008 | 02:37 PM
4Crawler's Avatar
Try the fuel pump test jumper or open the flap in the AFM with the ignition on:
http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Old Sep 7, 2008 | 02:39 PM
nolimit's Avatar
All fuses good but inside the driver side kick panel there is a black box that has several wires going to it but there is an orange wire with a inline fuse coming from the box connected to nothing any idea. Thanks
Old Sep 8, 2008 | 04:42 AM
nolimit's Avatar
See what ya'll think. I've tried everything that's been suggested. If I hook a hot wire direct from battery to hot leg on fuel pump will it hurt anything.
Thanks
Old Sep 8, 2008 | 05:10 AM
mt_goat's Avatar
Well, that would make the FP run all the time. It can be dangerious if you get in a wreck or something to have the fuel pump running with the engine off. When my engine swap was first completed I had a wiring issue that ran the pump anytime the key was on, I drove like that for a while before it was corrected. The unused fuel just gets returned to the tank by way of the fuel return line, unless there is a failure of the system somewhere.
Old Sep 8, 2008 | 05:16 AM
mt_goat's Avatar
If that does get it going you might want to check to see if someone has installed a fuel cutoff switch somewhere that you don't know about.
Old Sep 8, 2008 | 05:36 AM
nolimit's Avatar
Thanks I just what to get it up and running I'm not giving up on finding the true problem.
jbv808
Aug 6, 2021 04:47 PM
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
gary4runner
Sep 24, 2015 12:53 AM
shisha1999
Jul 13, 2015 11:09 PM
