fuel issue
Old 06-21-2007, 08:05 AM
91TPU's Avatar
fuel issue
ok so i get in my truck this morning to drive to jury duty, turn it over and its very rough, then it starts up gets up to the idle position when the motor is cold and then shuts off. everytime it did the same thing, i tried to feather the throttle to keep it alive, but it shuts right down no matter what...gas was low, but not all that low. so i put another two gallons in incase it wasnt getting gas, still nothing.
so here is what im gonna do
1-change the fuel filter
if its not that
2-pressure check the lines
if its not that
3-try and jump the fuel pump
if its not that
4-check the connections on the top of the fuel tank to see if they are corroded and need replacement.
if its not that i dont know what else to check.
any ideas, truck ran perfect yesterday, tune up has been done within 5k, timing belt within 30k, anything else you guys/gals can think of?
edit, and yes i searched and read quite a bit, just looking for more info
Old 06-21-2007, 09:19 AM
ewong's Avatar
how did you pressure check the lines?
Im guessing rusted lines along tank - lack of pressure...
Old 06-21-2007, 09:20 AM
CJM
CJM's Avatar
EFI fuse?
I feel for ya Joe. Oh and that rad is about 125 or so according to my guy. call me and let me know will ya!
Old 06-21-2007, 02:14 PM
91TPU's Avatar
one of my neighbors is a toyota mechanic, he said he can check for pressure. i would assume off of somewhere near the fuel rail or something. i do not know tho, i will after he does it
not rusted lines, they were replaced less then 50k ago, checked them all, they are all good. and there is no fuel on the ground...
tried to get at the fuel filter, and i just couldnt get the darn tranny crossmember off. i cracked all the bolts on the passenger side no problem, but couldnt get the four on the drivers side off, tried by hand, by hand with a long wrench and cheater bar, with an impact gun, heated with MAPP gas and by hand, again with MAPP and with the impact, they didnt budge a bit, so i have no clue what im gonna do, i guess im gonna have to cut the bolt head off, then drop the crossmember, and then figure out how in hell im gonna get the rest of the bolt out, really not too keen on drillin em and tappin em, just feel as tho its weakening the one side.
Old 06-21-2007, 02:15 PM
91TPU's Avatar
Originally Posted by CJM
EFI fuse?
sorry i havent gotten back to you dude, things have been hectic lately, with working on the truck, trying to get a job, jury duty and being put on a 5 day trial, i just havent had anytime to do anything! that is def a good price, as soon as i have the cash ill let you know...prolly take me about a month or so, cuz i gotta pay some bills with my first paycheck
Old 06-21-2007, 03:59 PM
91TPU's Avatar
looks like its the fuel pump, its getting pulled tomorrow
Old 06-23-2007, 05:51 PM
91TPU's Avatar
replaced fuel pump, lines, filter....wasnt that, so then we checked all the fuses, they were good, checked the relay, good. finally figured out i was only getting power at the fuel pump for the first 3 seconds the car was on, so i jumped the diagnostics plugs for the fuel pump and power and now it runs and works fine...so far were totally stumped...and im working with a toyota mechanic on it...
Old 06-23-2007, 05:54 PM
91TPU's Avatar
used a fuel pressure gauge...should be reading 38-40psi at idle, more under load...i was getting 40 at startup, then it would progressivley drop until the truck shut off
Sleaker
08-26-2020 06:03 AM
raptor510
02-17-2017 07:11 AM
pyramid
07-30-2015 10:05 AM
smiley52
07-11-2015 05:16 AM
nick b
07-11-2015 04:38 AM
Quick Reply: fuel issue
