Fuel Injectors
Old Nov 17, 2007 | 07:33 PM
langzaiguy's Avatar
Fuel Injectors
Welp, I'm in the middle of a HG replacement. Got to a good stopping point--I got 2 head bolts that don't want to come off--I'm sure you can guess which ones. I put PB Blaster on them and I'll mess with them tomorrow.
Question: I have the injectors out. 2 of the 4 had little brittle greenish black caps on the ends--they eventually broke off. The other 2 are fine. Can I purchase new "end caps" for them or do I have to replace both the injectors? I'm planning on sending the injectors away to be cleaned, but I won't if I have to replace 'em. Any ideas?
Old Nov 17, 2007 | 07:58 PM
MAXIMUS1968's Avatar
I used this guy, he did a great job and gave me flow tests before and after.....alot recommend Witchhunter as well
http://cgi.ebay.com/ebaymotors/ws/eB...135308437&rd=1
Old Nov 18, 2007 | 07:28 AM
langzaiguy's Avatar
Looks like a great reference! The "pintel" or "pintle" caps were what I was referring to. I think I'll go with your reference over witchhuner (which was what I was going to go with in the beginning). Your reference is cheaper, they mentioned that they replace the pintel caps and their ebay rating is great. Thanks for the tip!
Old Nov 18, 2007 | 08:19 AM
gametom's Avatar
rich from cruzin performance
he replaced the o-rings and pintle cap and you get a flow test
also he cleaned my cold start for free
Old Nov 18, 2007 | 09:52 AM
langzaiguy's Avatar
Now where, in comparison to the other injectors, is the cold start injector located?
Old Nov 18, 2007 | 10:04 AM
Blurr's Avatar
Rich from Cruizn is backed. top quality work, quick turn around time
Old Nov 18, 2007 | 10:08 AM
BLKNBLU's Avatar
Another thumbs up for Cruzin Performance. Your injectors will come back ready to install.
Old Nov 18, 2007 | 10:26 AM
thook's Avatar
Was this price for all 4, or just each injector?
Old Nov 18, 2007 | 10:54 AM
All 4 injectors, he did a great job! With flow comparisons before and after
Old Nov 18, 2007 | 11:02 AM
Blurr's Avatar
another quick comment on Cruizn Performance's work... I've read several posts on this forum about having injectors tested/cleaned and having them 'stick' if they aren't installed soon after. i didn't install my injectors for about 6 weeks after I received them back from Cruizn, no problems whatsoever.
Old Nov 18, 2007 | 11:07 AM
thook's Avatar
Sounds real good. I'll have to look into getting it done at some point. Thanks.
Old Nov 18, 2007 | 03:14 PM
superscreenname's Avatar
Sounds like cruzin is the place to send em. Anyone have contact info handy so I don't have to do a search. hehehe
Old Nov 18, 2007 | 03:42 PM
langzaiguy's Avatar
http://www.cruzinperformance.com/ is their link.
Has anyone who has used Cruzin or WitchHunter know if they also replace the pintels?
Old Nov 18, 2007 | 03:53 PM
SCYOTA's Avatar
It is located on the drivers side of the intake plenum. It will have a metal fuel line (the little one) and electrical connector going to it.
Old Nov 18, 2007 | 06:28 PM
BLKNBLU's Avatar
Cruzin does.
Blamalam
Mar 12, 2022 07:34 AM
RatOmeter
Oct 22, 2015 03:17 PM
Tacoma1313
Aug 17, 2015 05:44 PM
pyramid
Jul 30, 2015 10:05 AM
HookahRoo
Jul 20, 2015 07:06 PM
