fuel filter help 22ret
Old 08-09-2007, 07:31 AM
swerks's Avatar
Question fuel filter help 22ret
I can not find mention of a fuel filter in my factory service manual ? can any one tell me where the fuel filter is located on a 86 4Runner turbo or direct me to a write up ? also a part number for the fuel filter would be helpful if any one has it.
Thanks
Old 08-09-2007, 07:43 AM
rdlsz24's Avatar
I'm guessing it's on the passenger side of the block right by the starter like on the 22RE.
Rob
Old 08-09-2007, 07:51 AM
keithguts's Avatar
Rob
X2 on this. It is right by the starter.............
Old 08-09-2007, 08:22 AM
swerks's Avatar
any way to get at that without removing the starter???
Old 08-09-2007, 09:00 AM
keithguts's Avatar
Well my partner had to remove the starter from his 22re 1988 pickup.
Old 08-09-2007, 10:05 PM
longhungsilver's Avatar
i didnt remove the starter.. just keep at it, its a tigh squeeze but u dont need to remove the starter
Old 08-11-2007, 11:31 AM
trd90toyota's Avatar
I'm pretty sure the part number is the same. Call the dealership with your vin and they can tell you.
Old 08-11-2007, 01:12 PM
notanymore's Avatar
get a friend with skinny arms and its no big deal. at least on a 22re im not sure if the rte is any different but i think it would be on pass side under the intake thing
Old 08-11-2007, 03:47 PM
conman's Avatar
Yeah, it's not impossible,,,,,,,I just did it myself. take the small fender plate off, get yourself a 1/4" drive T - Handle wrench or ratchet and a couple of at least 6" extensions or 1 long 16" or so and a 1/4" swivel and 12MM (short) socket. remove the fuel lines before you loosen the bolts going in the block or you will have a hell of a time trying to hold it and turn the wrenchs at the same time. good luck and a little patience goes a long way. PS it wasnt even my problem, turns out there is no gas getting from the tank to the filter. now to remove the gas tank........................
Old 08-11-2007, 03:57 PM
frm_808's Avatar
also helps to have a body lift LOL
Old 08-11-2007, 05:50 PM
ewong's Avatar
take off the inner fendwer well panel
Loooong extensions with a flex head fron the FRONT of the engine
lie down on the top of the engine and reach in with two hooked together wrenches to reach the rear bolt
ONLY two bolts hold the filter in
LOOSEN the fuel banjos before removing the mounting bolts...
Old 08-11-2007, 07:20 PM
mr toytech's Avatar
x2. that how i do them.
smthwsn357
12-04-2023 02:08 AM
Eggslinger
06-08-2019 03:32 PM
pyramid
07-30-2015 10:05 AM
ddg71
07-24-2015 01:24 PM
Fundy Rider
07-16-2015 01:35 AM
Quick Reply: fuel filter help 22ret
