Flywheel + bellhousing
Old Nov 11, 2007 | 06:02 PM
gametom's Avatar
i can't get three of the flywheel bolts out. i used the impact them and three came out the others don't budge how can i get the rest out.
also what can i use to clean out the bellhousing is brake clean ok or is there something better
Thanks
Old Nov 11, 2007 | 06:04 PM
DeathCougar's Avatar
try heating them up. You would always put a breaker on the front crank bolt to hold the engine still, then get another breaker for the flywheel bolts.
or get a bigger impact gun lol
Also brakecleen works great, especially with a wire brush or similar tool.
Old Nov 11, 2007 | 07:07 PM
notanymore's Avatar
you could try some penetrating oil, and then what deathcougar said with the breaker bars
Old Nov 11, 2007 | 07:59 PM
idanity's Avatar
PBBlaster (imo) is a good investment, (that and the breaker bar + bigger impact gun)
Old Nov 11, 2007 | 08:36 PM
rowdy235's Avatar
heat it up (i usually use my oxy-mapp setup) until it just starts to turn red. Then spray Deep Creep where it meets the flywheel. The heat will draw it in, then get 2 huge breaker bars and put one on each end. Just be careful not to heat it up too much and melt it.
Hope this helps.
Old Nov 11, 2007 | 08:49 PM
PB blaster is a great product, but there really is no way to get it to the threads. Kind of a waste of money in this case.
Old Nov 11, 2007 | 09:17 PM
gametom's Avatar
there no way to get to the threads for pbblaster to work, and oil on the flywheel is not a good idea.
with the torch i can't get to any of the metal surrounding the bolt just the bolt head it self.
a breaker bar on the crank sounds like a plan tho.
Old Nov 11, 2007 | 09:40 PM
gametom's Avatar
ya mines only rated for 230 ft lbs
Old Nov 11, 2007 | 10:03 PM
Lysmachia's Avatar
Well after getting the other bolts off didja get the flywheel off? (Aside from using the bearing removal tool that *always* breaks...)? Someone here told troy and I some "newspaper trick" which we never had to try since we (O.K. HE) spent 8 hours dremmeling that rotten flywheel to get it off before reading the newspaper tip...
Let us know how it goes!
Old Nov 11, 2007 | 10:44 PM
gametom's Avatar
What is the newspaper trick?
Old Nov 11, 2007 | 10:46 PM
say to hell with it and take it to a shop, and read the newspaper while THEY struggle with it!!!
naw, not really. I want to know as well!
Old Nov 12, 2007 | 03:36 AM
Targetnut's Avatar
Originally Posted by yota4runna
Sounds like a wimpy impact problem!
A bit more "impact" will probably do the trick. Try turning up the air pressure to 140psi-150psi also add some air tool oil to your gun through the air fitting. These things will substantially increase you impact's output.
Of course you'll want to turn the pressure back down when you are finished.
brakleen will work, but what works better is spraynine, topjob, or some other good detergent. I use detergent to clean alot of things. it works bewtter than solvents on most stuff.
Old Nov 12, 2007 | 04:23 AM
Lysmachia's Avatar
Awe carp.... (I spelled the fish name instead of doggie poo) On purpouse cuz I now haf-ta go find that ole' newspaper suggestion to get the flywheel off. It sounded legit. Really it did. But we never got to try it.... *sigh*
Loocking....
Loocking....
Loocking....
Old Nov 12, 2007 | 05:46 PM
gametom's Avatar
well i got the flywheel off eazy the bearing is stuck in tho
and the flywheel was unmachine able so i have a new ome one on order
Old Nov 12, 2007 | 07:54 PM
gametom's Avatar
got the bearing out in with the grease trick in about 10 min
Old Nov 12, 2007 | 09:24 PM
just a 22re's Avatar
um............ about that eatth quak thingy yeah just becareful when i worked at my old shop the only time we used it was well to brake the studs bolts or what ever completely off there very good at doing that and with hat on the flywheel thats a bigg no no uneven heat on that and you got a warped flywheel thats just no more good to ya anyways just my .07 cents
camel_65@hotmail.com
Oct 3, 2018 06:11 AM
beebeeri000
Oct 2, 2015 10:42 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
93toyoguy
3.4 Swaps
10
Sep 18, 2015 04:16 PM
