Finicky oil light..
Old Sep 8, 2008 | 08:20 PM
project91's Avatar
Finicky oil light..
My 91 3vz 4x4 is having a weird problem..at idle..there is no oil light on on the dash..while driving it comes on and remains on but sorta dim and flickery, let my foot off the gas and it goes away..running Mobil1 10w40....whats the dealio?
Old Sep 8, 2008 | 08:22 PM
iamsuperbleeder's Avatar
bad sensor maybe?
have you ever replaced it?
check it for leaks too...
Old Sep 8, 2008 | 08:25 PM
rowdy235's Avatar
check oil level, check with mechanical gauge, if everything checks out there, replace sensor.
Old Sep 8, 2008 | 08:27 PM
project91's Avatar
No leaks...I hate a leaky engine and make sure I fix and prevent any....Where is the sender on the 3vz..I may just swap to a mechanical gauge and check the pressure manually..it seems odd because to me if I had a problem it would be the reverse of the way its happening..it should come on at idle, and go away at higher RPM's where the pump is turning faster...?
Old Sep 8, 2008 | 08:32 PM
Originally Posted by rowdy235
check oil level...
now why didn't I think of that...
theoretically yes, assuming the sensor AND the oil pump is still good...
as far as where that sensor is on that motor, that's outta my field... imma 22re guy, sry...
Old Sep 9, 2008 | 08:39 AM
project91's Avatar
Alriht I connected a manual gauge to it today and at idle..it shows 80 psi...rev it up it goes to around 100 psi..very high when compared to the Haynes manual specs...!
Old Sep 9, 2008 | 09:03 AM
Squiddy's Avatar
These pressure numbers are pretty much what people around here get for the 3.o at start up and initial idle. Goes to 100 with rev. Once settles, down around 25.
The wire coming off the pressure sender is prone to bend/break at the sensor end. For pics on all this, see my recent link:https://www.yotatech.com/forums/f116...ensors-153167/ , I am going to update with my own pics when done (soon)
Old Sep 9, 2008 | 10:21 AM
abecedarian's Avatar
seriously?
sounds like the pressure relief valve is sticking.
but even 80 is high at idle, so there may be something plugging a passage down near the pump.
Old Sep 9, 2008 | 11:15 AM
just a 22re's Avatar
was that checked at hot or cold?
Old Sep 9, 2008 | 12:30 PM
an oil pressure chart I found lists 3vze normal oil pressure at 4000 rpm should be between 36-71 psi
sounds like a problem
Old Sep 9, 2008 | 12:49 PM
MMA_Alex's Avatar
I don't know what pressure the regulator valve kicks in @ on the 3vze, but I doubt its anywhere near 80psi...
Old Sep 10, 2008 | 05:22 AM
Squiddy's Avatar
Maybe I am about to explode, but, like some others:
About 100 at cold start up
a few minutes later 25 at stable idle/cruise
bumps up as high as to 75 during acceleration
Old Sep 10, 2008 | 06:28 AM
MMA_Alex's Avatar
Just checked the fsm
3vze: 93 fsm says 77 psi on the relief valve
  • 4.3 psi @ idle
  • 36-75 psi @3k rpms
22re: 85 & 93 fsm say 64 psi on the relief valve
  • 4.3 psi @ idle
  • 36-71 psi @3k rpms
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Toyvana
Jul 29, 2015 10:47 PM
yourrealdad
Jul 29, 2015 11:08 AM
irritech
Jul 27, 2015 05:15 PM
calderp
Jul 27, 2015 09:58 AM
